fuel injectors
Old Jan 26, 2010 | 04:50 PM
hondajosh1's Avatar
Default fuel injectors
i have a 97 integra gs stock with just exhuast and intake.
i just bought a t3/t4 turbotecnics turbo kit. along with a skunk2 intake manifold.
my question is do i HAVE to get fuel injectors for my car to run properly with the turbo?
any help would be appreciated.
thanks
-josh
Old Jan 26, 2010 | 06:20 PM
LU!SKEY's Avatar
Default Re: fuel injectors
Yes i believe you do need injectors, what size i dont know you need to be more specific as to what you pwer goals are, what does that kit come with? what size trubo is it? research my friend research will take you a long way!
Old Jan 26, 2010 | 06:45 PM
GagnarTheUnruly's Avatar
Yeah def. need new injectors and what size depends entirely on power goals as ^^^ said. Stock runs out at 185 whp or so, I believe.
Old Jan 28, 2010 | 05:39 PM
hondajosh1's Avatar
thanks thanks
im not lookin for crazy power or anything.
ill be around 8psi.
but thanks
Old Jan 28, 2010 | 06:21 PM
Hawjap1gsr's Avatar
if you looking at 8psi only then 550cc should be good and give you room to upgrade in the feature. stock injector will run you out to lean which is bad for your motor.
Adam R.
Feb 19, 2013 07:38 PM
usdmDC4
Oct 14, 2007 11:07 AM
turbotime
Feb 24, 2006 04:02 AM
mrkal
Jan 22, 2006 05:23 PM
sevret.t
Nov 23, 2004 06:39 PM
