Fan switch not working for "1" and "2"
Old Jan 26, 2010 | 04:15 PM
///MPower's Avatar
New User
Default Fan switch not working for "1" and "2"
Have a 97 ek hatch and was running the a/c on "2" when suddenly it stopped. Now it seems I can only use the fan at "3" or "4". Any suggestions?
Thanks
Old Jan 26, 2010 | 05:47 PM
EgonzEk's Avatar
Default Re: Fan switch not working for "1" and "2"
most likely your resistor pack burned up. theres usually 2 or 3 resistors controlling your blower motor. one for speeds 1 and 2. the other for speed 3 or 4 or both. check them out.
Old Jan 27, 2010 | 07:49 AM
socale39's Avatar
I have the same problem too.
Old Jan 27, 2010 | 07:53 AM
2point2's Avatar
Basically, if any of the speeds fail except for the highest speed (full voltage) than there's a 99% chance it's the blower resistors.
Old Jan 27, 2010 | 08:07 AM
Meoshe's Avatar
JA1258 $27.99 at autozone is what you need. Its located behind the glove box in the blower unit, up top in the middle.
Old Jan 27, 2010 | 08:24 AM
Schister66's Avatar
Man U FTW
Look at this guy...part number, location and everything...nice work
Old Jan 27, 2010 | 08:27 AM
97twodoor's Avatar
Also check the blower motor amp draw. If its too high then you'll just keep going through resisotors.
shadhman
Jan 28, 2009 11:27 AM
schueytenten
15
Aug 8, 2008 12:28 AM
tigueremalo
Aug 15, 2006 08:09 PM
miksew
Feb 6, 2005 06:55 AM
