Semi-Interesting fact about the Integra Dome lights
Old Sep 5, 2002 | 07:34 AM
B2FiNiTY's Avatar
Default Semi-Interesting fact about the Integra Dome lights
I noticed this the other day, the dome lights are a little bit brighter when in the ON position rather than the automatic on when door is open position. Probably 5-10% difference.
B2 - who notices stupid things
Old Sep 5, 2002 | 07:39 AM
JPP's Avatar
JPP
Default Re: Semi-Interesting fact about the Integra Dome lights (B2FiNiTY)
Was the engine running during both situations. If not one was done when the alternator was supplying the current and the other when the battery alone was supplying the current. Might explain the difference.
JPP who somethimes notices stupid things also...but not that stupid
Old Sep 5, 2002 | 07:47 AM
B2FiNiTY's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (JPP)
Oh yeah. This was with the car OFF.
Old Sep 5, 2002 | 07:48 AM
AssPenny's Avatar
Boring day at work?
Old Sep 5, 2002 | 07:49 AM
B2FiNiTY's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (AssPenny)
Jet lag at home... I noticed this at 4AM in the morning.
Old Sep 5, 2002 | 07:50 AM
RTW DC2R's Avatar
Hyperwhite dome lights are the shizzle
Old Sep 5, 2002 | 07:52 AM
B2FiNiTY's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (RTW DC2)
PIAA Extreme White to be exact
Old Sep 5, 2002 | 08:06 AM
MackSpeed-616's Avatar
its b/c in ON it gets straight 12v w/o have to go through a relay (the one that is tripped by the door)
Old Sep 5, 2002 | 08:12 AM
B2FiNiTY's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (BustaNutt-616)
Exactly.
Old Sep 5, 2002 | 08:24 AM
BlueR's Avatar
dome light? this is what i think about that fuggin light...
Old Sep 5, 2002 | 08:43 AM
B2FiNiTY's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (BlueR)
That's why I swapped it out with another light that still doesn't do jack!
Old Sep 5, 2002 | 08:53 AM
B2FiNiTY's Avatar
Package. Note: Price is in NT
PIAA v Stock
Light it up:
Xtreme...Almost...:
[Modified by B2FiNiTY, 9:54 AM 9/5/2002]
Old Sep 5, 2002 | 09:33 AM
kkim's Avatar
I replaced mine with a higer wattage bulb from the local auto parts place. stock is 4 watts, I think... put an 8 watt bulb in there and CAN notice a difference for like the buck or so it cost me.
Old Sep 5, 2002 | 01:18 PM
nsxtcjr's Avatar
New User
Default Re: Semi-Interesting fact about the Integra Dome lights (kkim)
I'm getting an HID kit for my dome light.
Old Sep 5, 2002 | 01:20 PM
Type Goch's Avatar
New User
lol, Gordy!
Old Sep 5, 2002 | 01:30 PM
Eric R's Avatar
BustaNutt, your explanation is very close, with the diff. there's not a relay involved. Like you said, when the domelight switch is in the "on" position, the circuit closes direct to 12V (there is less resistence). When it lights up by the door pins it goes through longer conductors creating more resistence. That's why the light is less brighter. It's just a simple "ground" circuit.
Old Sep 5, 2002 | 01:31 PM
AssPenny's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (Tweety R)
Nerds
Old Sep 5, 2002 | 01:33 PM
Eric R's Avatar
Nerds
Old Sep 5, 2002 | 03:01 PM
R1525's Avatar
dorks!! hehe....pretty good observation. wonder what you do with that light to notice it.
Old Sep 5, 2002 | 03:07 PM
Comp97GSR's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (R1525)
Let us know if the plastic cover melts. ( Just in case someone leaves their door open long enough )
Old Sep 5, 2002 | 03:44 PM
$pecial K's Avatar
where can i get some of those hyper white dome light bulbs yo?
Old Sep 5, 2002 | 04:03 PM
mugenracer's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights ($pecial K)
i have 10,000,000,000,000,000 candle power bulbs to fit the dome light holder, only thing is they melt the roof when on and you'll go blind if you look at them!
Old Sep 5, 2002 | 04:07 PM
gblaue's Avatar
The bulb is constantly supplied with 12V. When you turn the light on via the switch at the light you completing a ground through the switch. The door switch does the exact same thing, except that the ground is through a long piece of wire, which has resistance. Therefore some of the voltage is dropped across the wire due to the resistance of the wire. The ground path of the switch at the light is a short path to ground and will have much lower resistance than the long ground wire, so more voltage is dropped across the filament of the bulb, thus it will be brighter.
Old Sep 5, 2002 | 04:33 PM
uNF$@#!'s Avatar
my god....$520 Nt = ~$20! (30 NT = 1 dollar)
Old Sep 5, 2002 | 04:38 PM
disordeR's Avatar
Default Re: Semi-Interesting fact about the Integra Dome lights (Soup ****)
bored much b2?
