JUST DYNO'D THE B16 COUPE!!!
JDM b16 in a 95 coupe
mods....
-Short Ram Intake
-RMF header
-2.5 exhaust piping (no cat/res - twin loop muffler)
-6 puck clutch
MAX POWER = 144.62
MAX TORQUE = 109.32
TEMPATURE = 56 F
HUMIDITY = 25%
what do ya think??
mods....
-Short Ram Intake
-RMF header
-6 puck clutch
MAX POWER = 144.62
MAX TORQUE = 109.32
TEMPATURE = 56 F
HUMIDITY = 25%
what do ya think??
na...no dyno before the install of parts...just was really bored today
and my plans are...valvetrain upgrade and a few other misc things and then NITROUS....prolly just a 50 or 75 shot.
Those numbers look right in the money!
I love it when you hear about people who throw on the I/E/H combo and expect 50hp, lol A dyno like your proves an extra 10whp and maybe 5 ft lbs torque....good example of real world numbers
Anyhow, good luck with your project! Cams can help wake up that engine, or find a B18C short block for cheap and swap it out if your looking for even more power.
^^he's right depending on which GEN B16A, they are different.
BUT your dyno numebrs look good. throw some cams in it! a slight upgrade from the ones you have now are GSR cams. they have a slightly higher lift and duration and can be found for cheap. also, you dont need to modify the head or anything at all.
preciate the positive feedback fellas....i was hopin for about 145-150 whp and around 100-105 tq. so i am very happy with those numbers.
the motor is from Hmotors incase anyone wanted to know...bad thing is....ive got to buy a work truck this spring so i am saving up for that....so the honda has to wait a bit to see some more performance mods. sooo in the meantime i am just going to baby it hardcore and maybe get some aftermarket mounts.
put the bottle on that thing. it will love you for it and n2o actually brings out alot of tq from about 3k on up. just make sure to get a bottle warmer if you live in a colder climate.
- "all" usdm B16A generations made 160hp at the crank
- 1st gen JDM B16A engines also made 160hp
- 2nd gen JDM B16A made 170hp at the crank (P30 pistons)
I think those are good numbers. Always depends on the dyno.
Ive seen stock B16s dyno at 110 hp with good compression. So your numbers are quite good.
Add bottle and be happy.
The B16a5 had 175 hp Found in the 96-00 SiR 2 (Ek4) (automatic transmission only)
The B16a4 which was also SiR 2 (Ek4) was 168 BHP (Manual transmission)
the a3 was the same as the a4 HP wise
haha
hmotors is good stuff.
