Climate Control problems!!!
The car is a 1995 civic hatchback cx.
Everything seems to be working, but the problem is that whenever I use the climate control on the highest speed setting ( fan speed #4) the wiring harness for the Climate control (the white 6 pin one, not the green one) begins to heat up and smoke right where it enters the fan speed switch on the back of the climate control cluster! It works fine on all the other speed settings. But if i keep it on #4 it will surely burn up...
What does this mean? The car looks like it has had the blower motor replaced, and all of the wiring looks to be in order? Could this mean i have a ground missing or a short somewhere? What should I check???
thanks alot!
thanks alot!
