Major electrical problems, 20+ hrs in 3 shops, nobody can figure out the problem
[SIZE="3"]I have a 2001 Civic Ex Sedan. There are five main problems: power door locks do not work; power windows do not work and none of the four are getting voltage at the fuse box; turn signal switch doesn't work, nor do they light up on the dash; wiper switch only works on medium and high, and does not squirt out any fluid; cruise control doesn't work. Also, inside the fuse block under the dash, some wires in the block have voltage when they shouldn't and others don't have voltage when they should. There is also a relay under the passenger's side dash making a clicking sound when you hit the door lock/unlock button, or manually push down the driver's side door lock (when it works it is a safety feature, when it is manually pressed down, it locks all the doors in the car).
I had a Compustar 5000 series remote start and alarm installed by an authorized compustar dealer. The next day, I went to adjust the shock sensor to a higher level, and on the following day (2 days after the alarm was installed), some problems started happening...
(I do not believe these problems have anything to do with the compustar install, and the only reason for listing the install is I'm trying to detail out exactly what happened and what aftermarket electronics I have on my car. The technician who did the install has not only been doing car electrical for 20 years, but is also extremely competent, has gone above and beyond what anyone in his position should be expected to, and has been a great friend through all of this. More likely than not, it is pure coincidence that these problems began soon after the install.)
I first noticed my remote wasn't unlocking my door locks, then I realized the power locks in the car weren't working as well; the door lock fuse wasn't blown. Gradually over the next month other things malfunctioned. It started off with my turn signals and parking lights after the door locks. The driver's side parking light would come on when I'd hit the arm/disarm button, but not the passenger side. Then when the headlights were on, the passenger's side parking light would come on, but not the driver's side.
If I pushed down the manual door lock (the rectangle manual push/push lock by the window) on the driver's side then my turn signals would stop working, my cruise control would go out, none of my four power windows would roll up or down, my wipers wouldn't work on delay, nor would they squirt out washer fluid. In order to get them working again, I'd have to turn the car completely off, remove the key completely from the ignition, and wait 10 seconds and turn it back on again (if I didn't remove the key, majority of the time, even if the car was left off for 10 seconds, none of the stuff would work).
There was also a freak problem that happened with the PDX 4.150. It may have nothing to do with anything, but I figured I'd mention it nonetheless. I had unhooked the main 0 gauge power from the distribution block to move the amps. When I went to hook up the 0 gauge power to the distribution block, it sparked bright blue, as usual; however the PDX 4.150 started pouring out smoke. I immediately removed the 0 gauge power from the distribution block and left it out, until I had removed the 4.150 from my car. None of the fuses on the amp had been blown, and has since been replaced by Alpine as defective under warranty. After removing the 4.150, I hooked the 0 gauge power back up to the distribution block, it sparked again as usual, and the other amps worked fine. Alpine had no clue what could have went wrong with the amp.[/SIZE]
WOW sounds like a trouble-shooting nightmare!!!! Hate to say it but if the problems started 2 days after the alarm install....... I would take it back to them. Could be a short circut or something internally with the alarm computer (maybe not an installation problem). Maybe have them un-install the alarm and see if the problems go away or replace the alarm computer with another one. I don't think your stereo setup has anything to do with the problem since it should be a seperate system only tieing in with the battery and head-unit.
Just my 2 cents but good luck.
I would say go in reverse and remove alarm or replace it. It might be causing conflicts in the wiring system since it does control everything that is not working correctly minus the wipers of course.
re2417
16
Jun 7, 2012 04:43 PM
littlecricket
Audio / Security / Video
Feb 28, 2012 08:14 AM
jmonroe0914
Jan 29, 2010 08:54 AM
Darren804
Nov 29, 2001 04:21 PM
