GSR Motor to ITR motor
Old Sep 5, 2002 | 07:15 AM
Cheeks153's Avatar
Default GSR Motor to ITR motor
As of right now I have an GSR motor and tranny in my hatch. I would like to put a ITR motor in it. Now since I have everything from the GSR motor is it possible to switch it over to the ITR motor ie. ECU? Axles? Mounts? Finally should I even do this or just work with my GSR Motor?
Thanks ahead of time
Old Sep 5, 2002 | 09:09 AM
Majuniors_no_vtecfu's Avatar
Default Re: GSR Motor to ITR motor (Cheeks153)
gsr motor is just as good as an itr motor...i'd stay with a gsr for awhile if you dont like it then try the ITR....but you can get just as much power of a gsr and a ITR
[Modified by Majuniors_no_vtecfu, 3:12 AM 9/6/2002]
Old Sep 5, 2002 | 09:32 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: GSR Motor to ITR motor (Majuniors_no_vtecfu)
Minus the money you'll be putting into it. It depends on where you want to go with the motor.
Old Sep 5, 2002 | 09:47 AM
Finest's Avatar
Unless you can make a PROFIT selling your B18c1 for a B18c5, I would say just stick to the GSR and build on that. An ITR is basically a mildly built up N/A B18c1 from Honda. You can get aftermarket parts that'll make the B18c1 produce much more HP than a stock ITR, and probably end up spending the same amount as locating and buying a legit B18c5. Just my 0.02.
Old Sep 5, 2002 | 10:18 AM
Cheeks153's Avatar
I was looking at staying in NA so thats why I would switch to the ITR motor. I've heard that for NA setups that the ITR was the way to go.
Old Sep 5, 2002 | 10:47 AM
Apex i ITR's Avatar
Like Prelude RCR said, unless you you sell the current motor you have for a good price, it probably wouldn't be worth it.
Old Sep 5, 2002 | 10:49 AM
owen_the_soyboy's Avatar
Default Re: GSR Motor to ITR motor (Prelude_RCR)
Old Sep 5, 2002 | 12:42 PM
Trey's Avatar
25 Year Member
Default Re: GSR Motor to ITR motor (owen_the_soyboy)
The ITR tranny is better for a NA motor, shorter gear ratios and an LSD.
Old Sep 5, 2002 | 12:44 PM
Apex i ITR's Avatar
Not for 2500 bux unless you have a hookup.
BuCU
Apr 3, 2017 01:05 AM
shockerjoe says
May 27, 2010 10:10 PM
crx_0_o
Sep 8, 2006 09:05 PM
eddiecut
20
Jun 8, 2002 02:39 PM
hypnoticz
Nov 8, 2001 06:26 AM
