b20 block with ls internals?
i recently cracked my b18a1 block and came across a b20 block for a steal. i was wondering if my internals from my a1 would fit in the b20 block? will it raise the compression? or lower it? is it even possible? any help is greatly appreciated
correct. for the most part, a b20 is exactly the same an ls except for as stated above about the pistons being 84mm instead of 81mm, and the intake manifolds are different. but as you are using only the b20 block, you won't have to worry about the intake manifolds being different.
b20veghathc
12
Oct 5, 2010 07:16 AM
