vtec help...
Old Jan 25, 2010 | 06:52 PM
tthoj's Avatar
Default vtec help...
okay i did a b18c5 swap not to long ago and is still trying to finish up. well i got into some more problem now and is frusrtated. At first i though that my vtec wasnt working at all because some of my CEL was still on, and so i fixed it and got all the CEL cleared. In case, if any help,FYI i used my civic dx harness with a immbolizer removed by katman. Then i followed the FAQ of vtec wire etc on HT here. so vtec was wired, KS, bypass CFK for all CEL to clear(wired directly to ecu).
then i was seraching around and found out that my oil level/pressure cant be low for vtec to engage(checked, and oil is not low). v-tec solineid has to be working( checked, used a chipped p28 and vtec engaged). but one thing i am uncertian of, my vss (Speed sensor) isnot working because my speedo and milage is dead, but here is the werid stuff i read that vtec wont engage if the speedo wont work correct?, however the CEL doesnt come on for the VSS. So i am assuming that my VSS works because my CEL doesnt come on and thier is a shortage somewhere( oh yea before the swap my speedo was working etc the speed sensor itself on the harness was working fine). So is it possible that my VSS died and some weird freaking reason my CEL wont turn on?
and the other thing I am assuming is that chipped p28 doesnt read vtec sensor whatever( wild guess here) and that vtec automatically engaged because chipped p28 was programed that way???? **** i dont know just throwing BS out there if it could be true.
Im beat!, so sorry for jumping from one thing to another. help please!!!
Old Jan 25, 2010 | 08:09 PM
civic_r87111's Avatar
Default Re: vtec help...
So it sounds like ur car is OBD1 and ur using the OBD2 P73 ecu, right? Well the OBD2 has a 3rd plug that goes to the gauge cluster for the speedo among other things. If I was u I would just use a chipped OBD1 ecu and get ot tuned for the C5.
Old Jan 26, 2010 | 09:38 AM
tthoj's Avatar
thanks civic r87111,
no my car is an obd2, a 98 civic dx hatch, and i am trying to get the car to be reff first before i go with a chip p28. also when the p28 was used, the speedo still didnt work...
thanks r87111
anyone else might know the solution?
Old Jan 26, 2010 | 10:10 AM
Well if the ecu isn't getting the vss signal then yes ur vtec will not work, is ur car OBD2a or b?
Old Jan 26, 2010 | 12:33 PM
texx72's Avatar
bump my car has the same problem and i cant figure it out either
Old Jan 26, 2010 | 01:08 PM
zedron's Avatar
+1
OBD2 ECUs in an OBD1 car = bad/dumb idea
Old Jan 26, 2010 | 09:42 PM
tthoj's Avatar
hey zedron, my car as i stated above is not a obd1 car, it is a obD2(a).
hey civicr87, my car is an 0bd2a and using the same engine harness not obd1 harness.
i also have the 0bd2a to obd2b jumper to run my p73 ecu, which works fine..
but like i said the weird thing about is, i think my ecu is not responding to the vss, but if my vss wasnt working then shouldnt my car throw a CEL? in some wierd reason the car is not throwing a code, and i have been driving this car for about 1 week and a half already not CEL yet. so i assume it works because the CEL isnt thrown but the speedo anit working
But then again, when i used the p28 using the 0bd2a to 0bd1 jumper to run it( forgot to mention this, might have caused some confusion.) the vtec kicked in fine and ran like a c5.
Old Jan 26, 2010 | 09:43 PM
tthoj's Avatar
thanks civic,
anymore help will be much appreicated!
thank you all in advance!
Thomas
Old Jan 27, 2010 | 01:44 PM
tthoj's Avatar
bump....anyone?
Old Jan 28, 2010 | 09:46 AM
So all ur gauges work in the cluster but the speedo? R u getting the priming CEL? There is only 5 things that determine if Vtec engages or not.
1. Temp
2. Oil pressure
3. Load
4. RPM
5. Speed
If u r sure all those r working and up to spec then I would say something is wrong with the ECU.
Old Jan 28, 2010 | 05:21 PM
tthoj's Avatar
yes civic r87, all gauges works except for the speedo, no i am not getting any CEL.
1.temp, when i rev to see if vtec works, i do wait until the car warms up.
2. oil pressure, my pressure is not low at all when i did the swap, i changed oil everything, i triple checked oil level everything is good to go.
3. Load? can you calrify this please.....
4. rpm, the rpm works find nothing wrong with it.
5. speed, this is the thing that is not working it might actually be the cause but i am not sure cause CEL is not thrown.
6.the ECu, we tried on another itr swap that we have, vtec works fine in that car and seems ecu is good.
only thing questionable about it 3 and 5.
lmk civic, thanks a lot i appreicate yoru time.
Old Jan 29, 2010 | 10:07 AM
On most all ecu's (exception of some tuners choice programs) vtec will not engage if the car isn't moving. U need to b driving and under a load for vtec to work, a load means the ecu detects the amount of power the engine needs to move the car. That is the best way I know how to explain it to u.
Old Jan 29, 2010 | 10:45 AM
zedron's Avatar
I see that now. When i quoted his post it was the only one posted. I quoted it and left the computer and didnt come back but went to bed then after work hit submit.
Old Jan 29, 2010 | 03:21 PM
tthoj's Avatar
civic r87, all 1-5 checked then, with the exception to number 5, i will try to get it fix this weekend, since no work on weekend, i will give u results back. I gladly thank you!
Old Jan 30, 2010 | 09:41 AM
Not a problem and good luck with the trouble shooting
Old Jan 31, 2010 | 10:52 AM
94teg-gsr's Avatar
im having problem with vtec in high rpm i put new oil pump nd fuel filter in help please
Old Jan 31, 2010 | 08:20 PM
tthoj's Avatar
Hey civir87,
man im glad u were able to help me, i double chekced item from 1-5, even trple check, and when i checked the wire that i extended for the vss, the ground wasnt giving power so it wasnt working, in which cases didnt thorw the CEL(i believe). well whatever the cases the problem been fix. I aprricate it a lot!
hey 94 teg-gsr, tell me exactly whats going on, i might be able to help. during high rpm, vtec is doing what?
Old Feb 1, 2010 | 08:49 AM
94teg-gsr's Avatar
Hey civir87,
the motor is still pulling but vtec is breaking up it starts around 5500 all the way to 8000
Old Feb 1, 2010 | 08:56 AM
ennohohbee's Avatar
^^check your Oil^^
Old Feb 1, 2010 | 08:58 AM
94teg-gsr's Avatar
its full
Old Feb 1, 2010 | 07:25 PM
tthoj's Avatar
check your vtec solinoid, clean it, see what happens
Old Feb 2, 2010 | 11:58 AM
Yeah, I would start with what tthoj said and go from there, sounds like a clogged oil passage. Unless u have a sensor dropping signal, u don't have a CEL pop then go out on when it does it?
Old Feb 2, 2010 | 12:25 PM
94teg-gsr's Avatar
screen is clean all wires have good connection mi oil pressure gauage is reading weird i never get more than 60psi when its warm or cold and the problem only occurs after driving for about 15-20 steady minutes...plzz help this problem is driving me crazy nd oh yeah when i first start mi car there is a squeling for about 1minute then goes away and ill have no oil pressure till the squeling occurs
Old Feb 2, 2010 | 05:19 PM
tthoj's Avatar
94teg, maybe your vtec solinied may be clean, but it may be broken?
also, does your car idle? because my brother car idles and his vtec is lagging choking, whatever u want to call it...
your ecu, what are you using?
like civicr87 say CEL?
Old Feb 2, 2010 | 05:37 PM
94teg-gsr's Avatar
idk i have two vtec selinoids and they both do it it idels its been laggin a little between 2k and 3500 rpm im using a p72 ecu it has always worked this problem jus poped up outta nowhere
