gsr/ls/sohc/h22/h23/trans/partspartsparts!!!!!!cheapcheap!!!!
EX:
tranny gear set - $40
differential - $20
trans (needs diff) - $50
gsr:
pistons + rods - $40
crank (needs turned) - $30
pickup tube $10
ls:
windage tray - $10
pistons - $20
crank pulley - $20
spindles/rotars/wheel barrings - $40
valve cover - $20
fuel rail - $10
head - $40
intake manifold - $20
timing belt cover - $15
IACs - $20
block + maincaps - $100
block freshly honed w/crank + ACL barrings - $200
block w/ARP head studs - KMS block gaurd - oil pump - water pump w/main caps - no crank - $200
b-series:
oil pumps - $30
flywheels- $30
starter - $40
stock exhaust manifold - $20
clutch - $20
water tubes w/thermostat housing - $20
plugwires - $10
half shaft - $40
altinator - $40
AC bracketts - $15
power steering bracketts - $15
driver side mount bracketts - $10
cam gears - $15
b16a pistons - $20
b16 cams - $40
timing belts - $20
d-series:
SOHC timing belt - $20
Fadanza flywheel - $30
flywheels - $30
starter - $40
clutch - $20
rear brackett - $10
d16 crank pulley - $10
d16z6 stock valve train - $20
d16z6 main gurttle - $30
d16z6 rods + pistons -$40
d16z6 cam gears - $10
d16z6 stock camshaft - $20
d16z6 head - $100
SOHC:
valve covers - $20
intake manifolds - $20
plugwires 8 1/2 mm magstar - $15
axels (used) - $30 (new) -$80
fuel rail - $10
unorthadox underdrive pullies - crank - altinator (includes altinator) -$80
H-series:
H22 pick-up tube - $10
H22a engine (apart) - $400
H23 head - $40
H23 STR t3 turbo manifold - $80
H23 obx intake manifold - $50
H23 engine - fully esembled - altinator - power steering - AC pump - full engine intake manny - all sensors - minus dizzy (don't know history) - $200
P75 ecu OBD2 - $50
P72 ecu OBD2A - $80
P2E ecu OBD2 (SOHC) - $50
OBD1 wiring harness - $50
OBD1 injectors - $20
OBD2A wiring harness (mint) - $100
OBD2 crank trigger - $20
water pumps - $15
head bolts - $15
honda horn - $2
oil pressure sender unit - $5
rear main seal cover - $10
del sol midpipes - $40
integra midpipes - $40
2 door civic midpipe - $30
99-00 driverside headlight - $20
96-00 cluster w/o tac - $20
random heater hoses - $5
fuel pump w/assembly - $10
magniflow muffler - $20
ibock lowering springs - $40
BLOX sandwich plate - $20
civic front calipers - $20
ebay front coilovers - $10
polyurothane shift linkage bushings - $15
tranny torque mount bracketts - $10
altinator bracketts - $15
stock mounts - $10
s1 JDM B16A XSI/RSI cable trans - $200
z6 head w/d15 bottom end (don't know history) - $150
92-95 jdm eg head lights with city lights and corners - $40
greddy muffler - $60
email: hawbakers_racing@hotmail.com
phone: 717-404-2206
thanks...bump please
differential - $20
gsr:
pickup tube $10
ls:
windage tray - $10
pistons - $20
crank pulley - $20
valve cover - $20
fuel rail - $10
head - $40
IACs - $20
b-series:
oil pumps - $30
flywheels- $30
starter - $40
clutch - $20
plugwires - $10
half shaft - $40
altinator - $40
AC bracketts - $15
cam gears - $15
b16a pistons - $20
b16 cams - $40
timing belts - $20
d-series:
flywheels - $30
starter - $40
clutch - $20
rear brackett - $10
d16z6 head - $100
SOHC:
valve covers - $20
fuel rail - $10
H-series:
H23 head - $40
P75 ecu OBD2 - $50
P72 ecu OBD2A - $80
water pumps - $15
head bolts - $15
honda horn - $2
stock mounts - $10
phone: 717-404-2206
got dibs on the GSR pickup tube! email pics to lthao61@hotmail.com Pm me paypal info and vouches please
where are you located. do you ship these parts from you or what? i really need the windage tray and want the ls crank depending on the condition. and maybe the ls oil pump. lemme know how i can get the parts. thanks
rwdkid
Apr 22, 2012 12:44 PM
nasteboyii
Jan 26, 2006 11:48 AM
