bad knock and grind - dies when push clutch
Old Jan 25, 2010 | 03:01 PM
douglaslovin's Avatar
Default bad knock and grind - dies when push clutch
for the past week it has had a bad knock.. mainly at high rev
today driving home it starting stalling a bit then something gave out. There is a bad knock/grind/wind like something is hung up but it runs if i give it a little gas.. but dies when i push the clutch to shift.
did i throw a bearing?
1990 civic hatch
DOHC ZC swap
its not timing. its not alternator. its nothing in the head.
Old Jan 25, 2010 | 03:07 PM
AndThenYouSay's Avatar
Default Re: bad knock and grind - dies when push clutch
I would say yes, but probably not in your engine since your clutch has nothing to do with crank shaft bearings.....
Sounds like a Tranny problem. Maybe your Throw Out Bearing or Input Shaft.
Either way you're pulling the tranny apart
Old Jan 26, 2010 | 06:56 AM
It locked up completely when in gear. had to ghetto tow it home.
for ***** and giggles i checked the oil and its very watery.. i hope i didn't crack the block
KhmerPride
Sep 13, 2014 06:31 AM
projectTeG
Transmission & Drivetrain
Sep 10, 2008 07:16 PM
CalhounBoi
Jun 11, 2007 10:33 PM
triple_s1x
Feb 19, 2005 01:34 PM
