HELP SRS LIGHT IS ON???
Old Jan 25, 2010 | 12:59 PM
carfreak2020's Avatar
Icon2 HELP SRS LIGHT IS ON???
Hey everyone the car is a 95 EJ2 and since i bought it a year and a half ago the SRS (airbag) lights been on and im now tired of it and i was wondering how to check the codes or figure out whats wrong with it ?
Thanks in advance
Jamie
Old Jan 25, 2010 | 01:23 PM
Default Re: HELP SRS LIGHT IS ON???
PLEASE.......
Old Jan 25, 2010 | 01:31 PM
Nichelson_Performance's Avatar
good luck man, the same thing happened to my brother's 2000 ej8 and we have yet to find out what the problem is. if you find it though i would like to know also, maybe the same thing could cause it in both obd1 and obd2
Old Jan 25, 2010 | 01:33 PM
ill make sure to let you know......thanks
Old Jan 25, 2010 | 02:14 PM
fungus mungus's Avatar
Factory wheel? Does your horn work? If not, your cable reel is probably damaged and will need to be replaced. If it does, you should be able to reset the SRS light. The helms manual tells you how to do this. Search the forum for "reset srs light" and I'm pretty sure you'll find a posting of that page of the manual. GL
fm
Old Jan 25, 2010 | 02:34 PM
yes its the factory wheel and the horn works too......but i want to read the code to know whats wrong with it before i reset it.....hows that done ?
Old Jan 25, 2010 | 03:52 PM
Old Jan 25, 2010 | 07:26 PM
Bump....please any one know how to find out whats wrong with the airbags?.....i dont wanna reset without knowing whats wrong
Old Jan 26, 2010 | 12:38 PM
Here is your answer. The connector is oriented 180 degrees differently than the RSX, but the procedure and codes are the same. GL.
fm
Old Jan 26, 2010 | 12:48 PM
thanks man......but thats for OBDII not OBDI
Old Feb 16, 2010 | 08:03 PM
b18tegg's Avatar
There is no way to know what is causing it...
Old Feb 16, 2010 | 08:40 PM
REDEM1FTW's Avatar
My buddy just unplugged the yellow plug on the back of the cluster and *WHOALAH*, no more srs light
Old Feb 16, 2010 | 10:01 PM
thatguylurch's Avatar
New User
yeah i would just unplug it from behind the cluster
helpmycivic
12
Jul 1, 2007 09:54 PM
berb_15
Feb 20, 2007 02:47 PM
pumafeet10
Aug 13, 2006 07:01 PM
dpine
Jul 24, 2006 06:00 PM
slowcivic888
Dec 15, 2004 06:32 AM
