Help Picking out good turbo cams.
Old Jan 25, 2010 | 12:36 PM
GSR_hatch936's Avatar
Post Help Picking out good turbo cams.
Ok im planning on turbo my gsr build that im putting together, well anywho i need help finding good, cheap, reliable camshafts.. Im having problems figuring out the lift/duration and what to look for, I plan on using 91 pump gas and I want around 350-400 hp. I have a port and polished gsr head with crower valves springs and retainers so I could just about use any cams. And i plan on using flat supertech valves, so if anyone has any good info or input please do help
Thanks in advance.!!!
Old Jan 25, 2010 | 12:40 PM
sanman000719's Avatar
Default Re: Help Picking out good turbo cams.
you can make 380 on 91 at 16psi man with stock gsr cams. I know quite a few people over 600 on stock cams
Old Jan 25, 2010 | 12:44 PM
hmmm... but i have a intake crower cam and a ctr exhaust cam sould i just stick with them?... and 380 sounds good to me
And really need some info on how to compare cams and understand what the specs mean..
Old Jan 25, 2010 | 12:46 PM
i was on a crower stroker kit in my b18c1 (first build) at 16psi it did 386/302 if I remember right the tq might be off but sounds right to me with the gsr cams
Old Jan 25, 2010 | 01:12 PM
Ok thanks for ur info bro
Old Jan 25, 2010 | 01:14 PM
yw man the info in my signature is on stock gsr cams as well
Old Jan 25, 2010 | 01:47 PM
boostedcivicsir's Avatar
Mr. Badwrench
i made 540 on stock gsr's with a b16.
i swapped them out for IPG's. if you can find them they are a great alternative.
Old Jan 25, 2010 | 01:54 PM
lol thats a first someone agreed with me haha
sorry just used to the haters man
Old Jan 25, 2010 | 02:21 PM
boostedEF91's Avatar
Go with a Set of typeR cams. lil better than gsr and you'll pull higher in rpm's. i made 434 on 17psi. and 460 on 20psi.. with a gsr bottom. stock head and typeR cams. So you'll hit your goals fairly easy.
Old Jan 25, 2010 | 02:34 PM
Ls_dx's Avatar
Gsr cams are proven and more importantly CHEAP!
Old Jan 25, 2010 | 03:14 PM
Soo toss out my cams?... Or should I keep and I have a question about exhaust, what size should I go with 2 1/2 or 3?.. And as far as using oem ctr or Itr cams would I have to get an up graded valve springs?..
Old Jan 25, 2010 | 03:34 PM
3in exhaust. !!
Old Jan 25, 2010 | 04:22 PM
Originally Posted by boostedEF91
3in exhaust. !!
Ok I might jus go with that..
Old Jan 25, 2010 | 04:53 PM
Anymore info on my other questions?...
Old Jan 26, 2010 | 08:08 AM
Well I also got a good deal on a skunk2 mega power exhaust and the piping is 2 3/4... What y'all think about that?.
Old Jan 26, 2010 | 08:16 AM
NO TURBO NEEDS TO BREATH, AND THE BIGGER THE BETTER WICH ALSO LEADS ME TO BELEIVE EFFICENCY OF THE TURBO WILL IMPROVE AS WELL WITH A BIGGER BETTER FLOWING EXHAUST i HAD MY EXHAUST BUILT 3" NO MUFFLER AND ITS FAIRLY QUIET
Old Jan 26, 2010 | 10:14 AM
Adam_b16a's Avatar
Why do you use caps lock?
Old Jan 26, 2010 | 10:27 AM
96 GSR-T's Avatar
I made 585whp/385tq 21-23psi with GSR Cams..... ITR Cams will give you a 35-50whp boost over GSR's though or you can just make the same power with less boost.
Use a good straight through 3" Exhaust.
Old Jan 26, 2010 | 06:27 PM
Ok thanks guys for all y'alls info!!
Old Jan 26, 2010 | 06:56 PM
i sue caps to **** off the ones thinking it all about yelling and not just a style of typing, but really im to lazy to take it off what ever its on higher or lower case i could care less
Old Jan 27, 2010 | 09:15 AM
EARLdaSQUIRREL's Avatar
official honda whore
for your power goals any oem cam would work and that skunk2 exhaust would work also (ive seen 450+ on 2.5")
Old Jan 27, 2010 | 09:19 AM
2.5" should be super quiet also
SiR-iNTEGRa
Mar 2, 2012 01:20 PM
oday
Aug 24, 2003 09:55 AM
GreenVillian
Nov 12, 2002 11:32 AM
VRxDReGoNxGSR
Jul 15, 2001 10:16 PM
