1991 acura integra vehicle speed sensor
Old Jan 25, 2010 | 10:58 AM
Urthwrite's Avatar
Default 1991 acura integra vehicle speed sensor
I am trying to locate the vehicle speed sensor (vss) on my 1991 acura integra ls. does the speedo cable link up to the vss? does the vss have what look like hydraulic lines (2) hooked up to it? I will post a pic of what I think might be it later.
Old Jan 25, 2010 | 11:45 AM
dalejrfan88's Avatar
Default Re: 1991 acura integra vehicle speed sensor
Yep that sounds like it.
Old Feb 2, 2010 | 02:28 AM
Urthwrite's Avatar
do you know what is contained in the tube lines and what would be the best way to remove them either without spilling any or spilling it into a container? do I even need to remove them? is there a way to test it to see if its broken, just needs maintenance, or is not the problem?
Old Feb 2, 2010 | 06:24 PM
EFcivichatch's Avatar
New User
I'm wondering the same thing, what are the lines for. mine isn't connected at all. the speedo cable is connected and my speedometer doesn't work
Old Feb 2, 2010 | 06:55 PM
Im pretty sure there is power steering fluid in the lines. I think thats what is used to lubricate the unit.
Old Feb 3, 2010 | 07:37 AM
the_augie's Avatar
thats right, those are p/s lines. the ones that lead to the p/s cooler to be exact.
inside that is the speedo gear. its my understanding that the vss is a part of the cluster.
Old Mar 11, 2011 | 06:47 AM
DAIntegra1992's Avatar
The DA Integra's power steering varies on how fast you are going. If you're doing 15 in a parking lot, you'll need more power steering. Same as if you're doing 100 down the highway you'll need less power steering. This is ran off the speed sensor, thus why the lines go through it.
Old Mar 11, 2011 | 08:08 AM
91_LS's Avatar
Here OP,this is my DIY on how the rebuild/clean the speed sensor on the G2 teg. Hope this helps some.
https://honda-tech.com/forums/showth...8#post44842278
sir_crx_says
Transmission & Drivetrain
Sep 9, 2013 09:53 AM
Hondakid4eva
Jan 26, 2011 06:16 PM
87hondacrx
Apr 23, 2009 08:08 AM
FREQUENCY 24.7
Feb 25, 2009 09:03 AM
Muckman
Nov 16, 2003 12:22 PM
