1996 honda accord wont start tried just about everything
Old Jan 25, 2010 | 09:26 AM
EF927's Avatar
Default 1996 honda accord wont start tried just about everything
car wont start tried everything to start i changed the main relay , fuel pump ,fuel rail, timing belt ,balance shaft belt ,distributor,coil,engine wire harness car is getting spark and plenty of fuel but car has no codes i scanned it multiple time car turnes over normally not fast i tried just about everything i can think of please if someone can help me let me know and the car does have plenty of compression
Old Jan 25, 2010 | 09:40 AM
1grex's Avatar
Default Re: 1996 honda accord wont start tried just about everything
That car should start with what you say there
Old Jan 25, 2010 | 02:09 PM
Jeul's Avatar
bad aftermarket part in there somewhere?
Old Jan 25, 2010 | 03:22 PM
punkassd's Avatar
IF you have all the things indicated, fuel, spark etc, then that leaves compression, but 1st chek your timing. just because you have fuel and spark doesnt mean your timing is correct and if its far enough out of whack it aint gonna start.. if your timing is correct then do a compression test. if your compression is bad its, overhaul time,, or easier, get another motor.
Old Jan 25, 2010 | 03:23 PM
punkassd's Avatar
oh and by the way you're not gonna get a code without the engine running to diagnose itself.
Old Jan 25, 2010 | 03:30 PM
punkassd's Avatar
appolgies,, i missed the part where you mentioned good compression. has to be timing. get some starting fluid too. blast some of that SH(^ in there and see if you get at least some form of wanting to start.
Old Jan 25, 2010 | 03:40 PM
tamadrummer1120's Avatar
you mentioned you replaced the distributor?
make sure you do not put the rotor on wrong...meaning in the wrong direction. this will send the electrical spark to the wrong wire at the wrong time.
and as mentioned above, check timing.
Old Jan 25, 2010 | 03:47 PM
mavvrik's Avatar
Hows your overall power? Are you getting full accesorey power i.e. lights and radio?
Old Jan 25, 2010 | 03:54 PM
TheMuffinMan's Avatar
He knows where you live!
Electrical portion of the ignition switch
mhcmm87
Sep 20, 2018 07:03 AM
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
kelviiv
Dec 17, 2008 11:19 AM
jweeks
Jul 14, 2008 04:35 PM
ericlee303
Apr 28, 2004 03:31 PM
