GSR 4th gear shift??
Old Sep 5, 2002 | 03:50 AM
IdotheSHOCKER's Avatar
Default GSR 4th gear shift??
Does anyone have a tough time throwing their car into 4th gear when shifting quickly??
Once in a while I have a difficult time putting the car into 4th. No grinds or anything.
My setup: 92 hatchback with B18C1, GSR shift linkage, stock integra shifter.
Old Sep 5, 2002 | 04:39 AM
Ohlias's Avatar
Default Re: GSR 4th gear shift?? (EGB18hatch)
Second gear is a bitch to me. Many time I have thrown it into 2nd and it just rebounds (pops) back out. No grinds but still very embarassing when you're trying to pass someone and all you hear is "vroooooooooooooom"
I think you might want to have you syncros checked, maybe one is worn out. I belive 1st and 2nd gear do not have syncros and I just chalked this up to my lacluster drving skills and the lack of those syncros...
Good luck
Ohlias
Old Sep 5, 2002 | 07:55 AM
Resurgent's Avatar
Default Re: GSR 4th gear shift?? (Ohlias)
Could be bent fork or syncs - 1st & 2nd have their own , 3rd, 4th & 5th by them self , reverse - none...don't ask how I know there about 150 - 230 $ each and ARE covered under warrenty. Hope this helps !
Old Sep 5, 2002 | 08:41 AM
PainfulTeg's Avatar
Default Re: GSR 4th gear shift?? (PlantedGSR)
actually i looked up the gears on alldata once and they said that reverse DOES have a synchro, just a different type.....anyone know for sure?
Old Sep 5, 2002 | 09:06 AM
Arsenal's Avatar
Default Re: GSR 4th gear shift?? (PainfulTeg)
The syncro is going to be 298 from Acura with no warranty. Easy to replace once tranny is out.
Old Sep 5, 2002 | 10:50 AM
Hairy Gorilla's Avatar
Default Re: GSR 4th gear shift?? (Arsenal)
I am 99% sure that reverse does not have a synchro. If it does it is nothing like the forward gears synchos. Thats why you can't put the car into reverse unless you are completely at rest.
I don't really know about the original problem...
Old Sep 5, 2002 | 10:56 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
the bitch for me is always 5th gear; im too lazy to throw my arm all the way to the right just to get in the gate really quickly. so it takes a lil longer for me to grab that. but 3rd and 4th are definitely the easiest (for me), can't explain why.
Old Sep 5, 2002 | 06:49 PM
grngsr01's Avatar
Default Re: GSR 4th gear shift?? (dLo GSR)
1 - 2 is by bitch shift. i love the 2 - 3 and the 3 - 4. THe 1 - 2 shift is alot harder to pull in than the others. Could that be due to the sycros needing to do their job???
Old Sep 5, 2002 | 07:02 PM
StinkyTofu's Avatar
Default Re: GSR 4th gear shift?? (grngsr01)
The spacing between 1-2 is greater than 2-3, 3-4, 4-5. So the synchros probably have to work harder when you're shifting really fast. Ever notice that daily driving, you bog 2nd gear if you're not careful? Shifting through all other gears are so much easier than 1-2.
Old Sep 5, 2002 | 07:05 PM
Kellindal's Avatar
Default Re: GSR 4th gear shift?? (StinkyTofu)
Agreed, 1 to 2 is a difficult one, and never seems as smooth as other shifts. But 3 to 4 is not problem. Simple flick of the wrist. Maybe you should look into the synchros. Did you buy the shift linkage used? Did you check it thoroughly before purchase?
snzh22
Dec 9, 2006 08:20 PM
9hatch6
10
Aug 28, 2006 06:03 AM
1992hludesi
Dec 9, 2005 08:52 PM
b20civic
Dec 2, 2002 05:28 PM
