diag help......
Old Jan 25, 2010 | 02:58 AM
mrtypes89's Avatar
Default diag help......
hey guyss! i own a 200 itr with 56k , i was racing my buddy yesterday on a closed strip( we both have py itr's) and i over reved the **** out of it on a misshift. i threw in the clutch and saved it as fast as i could but damage was already done. The car starts and runs,, but doesnt feel the same. it spuders when im at idle and has a more noticable knock then it already had. I also now have a blinking cel.... with codes p1302 ( cylinder 2 misfire). p1399 and p1457, im goin to check the plugs today . do you guys think i got luckky and didnt bend or burn any valves ? what other things mite i check if the plugs are good? I appreciate the help.
Old Jan 25, 2010 | 03:13 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: diag help......
Money shift.
You most likely bent exhaust valves. Run a compression test to confirm and prepare to pull the head.
Old Jan 26, 2010 | 05:27 AM
tipe R's Avatar
do a leak down test if you can, then you'll know which valve you bent if any
JBirch_97Prelude
Mar 9, 2021 03:01 PM
houstonteamer
Sep 15, 2009 09:13 PM
bOOsTiNSoHcVtEc
Nov 1, 2005 02:33 PM
itr817
Aug 3, 2003 12:48 PM
8400 rpm
Jul 28, 2002 08:57 AM
