transmission fluid and 5th gear whine
Old Jan 24, 2010 | 07:39 PM
eap's Avatar
eap
Default transmission fluid and 5th gear whine
hi i have a 91 civic hatch with a zc. i recently changed my transmission fluid. today i started to hear a whine in 5th gear and it popped out of gear once. is this because of the fluid? i used 10w-30. let me know what you guys use.
Old Jan 24, 2010 | 07:49 PM
harmonator84's Avatar
Default Re: transmission fluid and 5th gear whine
10w-30 what? motor oil?
Old Jan 24, 2010 | 07:53 PM
90civicstdgold's Avatar
try syncromesh.. or Honda's genuine MTF
Old Jan 24, 2010 | 08:48 PM
zsoccerdude17's Avatar
Always go with Honda MTF nothing else, using standard motor oil is not a good idea for many reasons.
Old Jan 24, 2010 | 11:10 PM
Syncromesh DOES work wonders though
To each his own opinion I guess...
Old Jan 25, 2010 | 09:47 AM
eap's Avatar
eap
ok thanks guys. i wouldnt hurt to run motor oil till my next oil change would it?
Old Jan 25, 2010 | 10:46 AM
yes it would. Think of honda engineered MTF the same way as the Honda engineered power steering fluid.
Old Jan 25, 2010 | 01:39 PM
freydaddy's Avatar
the Honda MTF is 10w40 engine oil. thats what my repair manual says to use; which i do.
Old Jan 25, 2010 | 03:00 PM
eap's Avatar
eap
well i was just using what alldata recomended. so can i got 1500 miles with 10-30 or should i change it immediately?
Old Jan 25, 2010 | 03:11 PM
AndThenYouSay's Avatar
If your popping out of gear I think some damage is already done. Do want to make it worse? Honda MTF for the win! If you don't see an improvement then you've got nothing to lose by trying synchromesh, but it's unnecessary for a healthy trans.
Old Jan 25, 2010 | 03:57 PM
bmanuhutu's Avatar
You can try Redline 75W-80 or 75W90, the 75W90 due thickness and need lil warmed up in the cold weather.
http://www.redlineoil.com/product.aspx?pid=46&pcid=7
I've tried 1 bottle 75W90 mixed with Honda MTF, solved prob.
Old Jan 30, 2010 | 03:02 AM
thebouncindj's Avatar
New User
would 80w/90 work as thats pretty much all i can find where i am located
95_Civic_4dr
Sep 16, 2009 10:05 AM
tmugg
Oct 20, 2008 12:09 PM
07galaxygrey4dr
Honda Civic (2006 - 2015)
21
Jul 27, 2007 10:12 AM
mattm868
May 27, 2007 03:21 PM
Ignitecivic
12
Apr 4, 2002 02:04 PM
