JDM d15b swap NO START (SEARCHED!) electrical?
Old Jan 24, 2010 | 05:26 PM
ticklemeermuel's Avatar
Default JDM d15b swap NO START (SEARCHED!) electrical?
hi guys got a small dilema here. I recently did a jdm d15b into a '94 CX. Not my first swap but it's the first time I've ran into this problem, so any input would be great! Whenever I try and start the car all I get is a starter (starter won't turn just a buzz) buzz, gauge cluster lights all flash rapidly followed by main relay clicking. I'm thinking it's more of an electrical issue because whenever I hit the hazard button on the hazards just stay on, they don't blink, or if I try and turn on the air the main relay clicks. I've never had this problem. I'm using the CX harness, and p05 ecu (I'm waiting for the p28 to come in), from what I understand those should be OK to at least get it started. I did not alter any/modify the wiring harness. Below are things I've checked and verified...
-main relay- Re-soldered to make sure all contacts are good
-Grounds- checked and made sure voltage/signals were good at the tranny ground, valve cover, and thermostat
Nando-tech
12
Oct 7, 2014 12:16 PM
lhd dc2
Mar 29, 2009 05:16 PM
progress
28
Jan 15, 2007 10:42 AM
mattie_96
Jun 21, 2006 04:08 PM
g-ride-si
Jan 13, 2006 08:14 AM
