want to swap a sohc vtec but dont know what i need
Old Jan 24, 2010 | 04:22 PM
J.D.M_EF9_SI's Avatar
Icon2 want to swap a sohc vtec but dont know what i need
hey everyone I have a 1991 hatch si all stock but i want to swap a sohc vtec i need to know if i have to change over from a obd0 to obd1 and also what kind of things do i need like ECU or wireing or anything at all thanks.
Old Jan 24, 2010 | 04:35 PM
frank_el_tanke's Avatar
Default Re: want to swap a sohc vtec but dont know what i need
do some searching in the FAQ, you'll find a lot of helpful info there.
Old Jan 24, 2010 | 04:48 PM
drift2004's Avatar
your gonna need a p28 ecu ,a jumper harness obd0 to obd1 to adapt the new ecu to the old harness-vtec distributor obd1-you can keep the stock axles,stock cable tranny stock motor mounts-since its an si engine harness you just need to adapt it to the new engine-you could go to the junkyard and cut off the plugs you need from a 92 civic si or ex model-and you need a throttle cable from an 92 civic si or ex.or you could get someone to wire it up for $120-200.the motor swap is easy because the engines are almost identical,no clearance issues or anything....
Old Jan 24, 2010 | 05:27 PM
thanks for the info i done B16 swaps before but am trying to stay smog legal a sohc seems way more simple
Old Jan 24, 2010 | 05:30 PM
alscrx's Avatar
Just search, that swap is old news, its everywhere!
Old Jan 25, 2010 | 05:16 AM
julioboostamante's Avatar
Drift pretty much covered it. If you need help wiring it up let me know as i have done this swap a couple times now. I use the stock plus from the MPFI Dizzy and use a 89 Teg green plug for the green/blue green/ yellow wires.
good luck!
Old Jan 25, 2010 | 02:47 PM
good luck!
thanks man I'll hit you up if I get stuck
Old Jan 25, 2010 | 04:41 PM
BiG ChOr!Zo's Avatar
http://ef-honda.com/ben/EFswapguide.php
Old Jan 25, 2010 | 05:17 PM
88crxjordan's Avatar
that swap guide helped out a lot for finding the rite engine thanks
r1cerocket7o2
May 20, 2014 12:22 PM
DA9Sleeper
Apr 15, 2011 02:38 AM
ERKK
23
Mar 9, 2009 04:25 PM
Charger69
Apr 20, 2008 03:54 PM
bigblockEG
Jan 2, 2003 07:47 AM
