Continuous blinks from ECU
my moms car is an 89 civic sedan Automatic. sometimes it starts sometimes it doesnt. ive changed the main relay but that doesnt help. this has been going on since the car was bought last year.
today i tried to on work it. cranked it and now it just doesnt start. then a check engine light comes on. so i lean over to check it and never before have i seen 16 continuous blinks.
i mean it does:
. . . . . . . . . . . . . . . . = 16 singles
usually it would be:
... . = 1 solid and 1 single would be 16, fuel injector..
what does the 16 singles mean? i know it isnt code 1 cause theres no pause and only pauses after 16 singles and starts it again.
but if it is code 16, how would i go about fixing that?
i mean it does:
i'm guessing your mom's car is dual point because it's an 1989. if that's the case, then the pm6 won't work or won't work properly.
btw code 16 is for the fuel injectors. check to see if they're getting the proper voltage.
OBD0 D-series ECUs don't have long and short flashes, only short - 16 flashes is code 16 for fuel injector - not uncommon on DPFI engines - probably needs one or both fuel injectors replaced
{EF9} GrEaZe m0nKeY
Aug 12, 2009 09:26 PM
NATEDEEZY
Jan 6, 2008 11:13 AM
AGPSuperstar
Sep 14, 2003 04:32 PM
