engine won't rev passed 6k???
Old Jan 24, 2010 | 12:01 PM
stickman78114's Avatar
Default engine won't rev passed 6k???
throws up a code every once in a while, im usually driving and havent checked it. code goes away and returns intermittently.
drives fine, but when i hit 6000 rpm it sounds like it's hit its rev limit.
stock CRX si, w/ stock engine, D16A6. stock as hell only has intake.
any ideas guys?
Old Jan 26, 2010 | 07:18 PM
Default Re: engine won't rev passed 6k???
it's throwing Code 1
Old Jan 27, 2010 | 05:24 PM
anyone?
Old Jan 28, 2010 | 07:24 AM
bump
Old Jan 28, 2010 | 07:29 AM
8dxhatchy8's Avatar
i thought code 1 was o2 sensor....but i could be wrong
Old Jan 28, 2010 | 10:22 AM
crx_si-r's Avatar
Why would you wanna rev your A6 past 6k to begin with?
Old Jan 28, 2010 | 10:28 AM
jbrokos307's Avatar
really and code 1 is o2 which throws your car into closed loop fix it but code 1 wont make ur rev limit change i have code 1 only cause my headers are p-off my ecu cause of the 02 bung location. my tuned rev limit is 7500 on my zc
Old Jan 28, 2010 | 12:18 PM
gator88's Avatar
My bet is that your tach is off and you really are at the 7200RPM limit for whatever it is. Our stock gauges are known to be off a decent percentage towards the end of their "needle sweep" and can be pretty optimistic on top end runs and misleading as an accurate RPM reading.
Old Jan 28, 2010 | 12:30 PM
D16SiHatch's Avatar
the a6's redline is only 6500rpm so its quite possible that the needle is off by a little
Old Jan 28, 2010 | 01:44 PM
8dxhatchy8's Avatar
that would be the best guess....
Old Jan 29, 2010 | 02:34 PM
i was told the redline is @ 7200. so yeah it probably is off a bit. gonna get a new o2 sensor asap, and just go w/ the stock tach for now.
thnx alot
Old Jan 31, 2010 | 08:21 PM
CRizzl JDM <3's Avatar
Look you are throwing a code for your o2 sensor and you should never take a single cam d16 past 6000rpms unless you have a chipped ecu or else if you do its not going to get fuel to ur engine and ur gonna blow dat beach up
but dats u speed ricer
Old Jan 31, 2010 | 08:50 PM
D16SiHatch's Avatar
o rly? that's not even close to being accurate
an a6 redlines at 6500rpm in stock form. y8 at 6900 rpm and z6 at 7200 rpm.
Old Feb 1, 2010 | 06:01 AM
~sp33~'s Avatar
EFB055
Not to mention how stupid 'chipped' ECU's are anyway. Like removing the rev limiter and making the car run rich makes it safer to over rev it somehow.
Old Feb 1, 2010 | 07:03 AM
hey fk you "CRizzl JDM <3Cox"
i really dnt need to hear dumb crap like that "dats up to you speed ricer"
wtf does dats mean? at least use good grammar dat's up to you.
anyway, im gonna stick w/ my rev being a lil off. i have enough for a jdm d15b now so im just gonna run this engine till it starts to feel weak. still runs great.
just a quick question, why did they make the y8 rev lower than the z6?
and to CRizzl JDM <3COX my bros stock a6 was taken to redline minimum of once a day for 8 months, swapped to a z6, and the a6 is still running in a friends car 1 1/2 years later.
Old Feb 1, 2010 | 01:24 PM
D16SiHatch's Avatar
my guess would be slightly different cam profiles. dunno if you've noticed before but vtec on the z6 kicks in about 600rpm earlier than on the y8.
Old Feb 1, 2010 | 03:16 PM
i dnt know that? yeah i wanted to get a zc but i think a new d15b would be a better choice and easier to find parts for.
thnx for the help guys
Old Feb 2, 2010 | 01:12 AM
~sp33~'s Avatar
EFB055
The sohc ZC is just as easy to buy parts for, and has more power.
ERKK
Dec 8, 2008 06:56 AM
kirbyman
11
Jan 16, 2008 03:07 PM
