Need help from the HONDA masters.....Please help
Old Jan 24, 2010 | 11:30 AM
ElectronSiB18C's Avatar
Thanks Honda-tech
Old Jan 24, 2010 | 12:19 PM
93egSLEEPER's Avatar
Default Re: Need help from the HONDA masters.....Please help
Fix the CELs and get back to us. Both of those would create this type of problem.
Old Jan 24, 2010 | 02:43 PM
knightsef-eg's Avatar
x2
Old Jan 24, 2010 | 03:03 PM
pArAdOxsqUArE's Avatar
i once bought a used dizzy and it would only bog around 4,000-5500 RPM. the o2 sensor shouldn't cause the problem but maybe the IACV could be an issue
Old Jan 24, 2010 | 03:14 PM
thanks
Old Jan 24, 2010 | 07:52 PM
could be alot of things.. try checking the timing.. might be off. or if you got time & money switch the harness.. might be a lose connection somewhere
Old Jan 25, 2010 | 08:03 AM
thanks
Old Jan 25, 2010 | 08:18 AM
Deetz's Avatar
Crazy Honda Guy
Why are you running a 1.8L ITR ecu? Obviously the maps are not the same, your B16 surely will not run optimum
Old Jan 25, 2010 | 09:09 AM
97ej6dx's Avatar
AHH yes its an issue with your fast idle control valve. ive had problems like that and the IACV light goes on because the fast idle control is connected via coolent lines to the IACV but basically there is a spring in the fast idle control that some times can work itself loose . but can be easily fixed by taking it apart and tightening the flat head style screw keeping the spring down there.. I was amazed when i found this out
Also make sure your IACV plug wires arent freyed that caused a problem in mine 2
Old Jan 25, 2010 | 10:18 AM
thanks
Old Jan 25, 2010 | 03:47 PM
thanks
Old Jan 25, 2010 | 05:50 PM
HondaPartsHero's Avatar
Technical Hero
just curious but did you ever do the 3 to 2 wire IACV conversion? If so is it wired correctly? Is your O2 code for the primary or secondary O2?
Old Jan 25, 2010 | 05:56 PM
97ej6dx's Avatar
Originally Posted by ElectronSiB18C
I also tried a delsol ecu B16 and it acts the same. And the motor is 99-00 so I don't have a fast idle. I wish it was that simple . Thanks tho. the only thing left is its gotta be the harness somewhere.
Thats interesting i guess i still have the OBD0 intake many on my 99-00 motor as soon as i get the cash ill change that so i guess i didnt know that the fast idle was the older gen. that makes sense bcause the 99-00 doesnt have that vacuum pot on the top of the TB either to keep the butter fly from moving to much during engine breaking
Old Jan 25, 2010 | 06:41 PM
97ej6dx's Avatar
You should have a fast idle there is another guy that has a post that has a 99 and he has one
Old Jan 26, 2010 | 05:49 AM
thanks
jayscivi
Dec 20, 2011 10:28 AM
'93 STULUDE
May 13, 2011 12:22 PM
LamboLude
Jul 16, 2006 10:57 AM
FG Two
Mar 30, 2005 10:05 AM
D16a6 2NR
Nov 23, 2003 10:21 PM
