help with my s2000 antenna for my del sol
wasup h-t i need help installing my s2000 antenna on my honda del sol. I have the antenna already but im not sure how to put it in so i can listen to my radio. Do i need an adapter?
if i were to do it, id block off the del sol one and cut a hole on the 1/4 panel near the trunk, were the s2000 has it..then find a way to mount it. you should take a look at the DA and DC chassis they have their antennas mounted in that spot..just my .o2
just cut the antenna wire and splice two wires one to the inside wire and one to the bradded wire that wraps the inside wire without the two wires touching and spread them apart and mount them inside you car or trunk...then you can just shave the stock one
DelSolMike
Jun 1, 2013 02:01 PM
