hasport shift linkage question
I have this hasport shift linkage and today I noticed that my shifter was kinda loose so jacked the car up went under inspected underneath the shifet all bolts were tight and when I wiggled the shifter the rod underneath the car its loose. Inspected it towards the tranny thn there it was. im not too familair with the names but see where the joints are that joins that rod for your shifter under the car the bottm part of that joints was broken. Can i just drill this thing out and put a bolt and nut and some thread lockers or the whole thing has to be replaced. And if it has to be replaced can an ITR shift linkage fit on an ej6 with a b series swap in it. please let me know so I wont event ry fixing this. But its not that part where the bushing goes it a little bit down before the bitch pin. i will include a pic where that black box the joint is somewhere there. Oh yeah thnks to whoever pic is this i borrowd it hehe.
No answer common. Okay then i did it already jsut in case someone breaks this is how I did it. I drilled out the end the punched out the bolt than replaced it with another bolt that perfectly fits make sure its snug and tight then on the thread some thread lockers and then the nut. Oh eyah also replaced the little rubber washers.
WGFletch4WS
Jun 6, 2011 05:55 PM
BDogggUT34
38
Apr 11, 2005 02:19 PM
