COMPLETE PART OUT
Old Jan 24, 2010 | 12:17 AM
boost fed ls's Avatar
Default COMPLETE PART OUT
Well after having electrical ussues with my hatch I decided to part out the project. Most of the parts i am selling are brand new.
Complete Turbo kit comes with the following
Garrett t3-t67 H.O
Slowmotion Top mount mani
Tial 44mm wastegate
Custom intercooler piping with couplers and t-bolt clamps
Precision 500hp intercooler
Hks ssq bov
custom 4 bolt to v-band adapt.
3in stainless down pipe with 2 o2 bungs
oil feed and return lines
SOLD!!!!!!!!!!!!!!!!
Fully Built complete B18c1 swap
Darton 84mm sleeves
Cp Pistons
Manley turbo tuff rods
ACL bearings
oem water, oil pump
ARP head studs
Cometic Headgasket
P&P head
Supertech valves and valve springs
ITR Cams
Edelbrock Victor X mani
Edelbrock Throttle body
Hondata intake gasket
Fluidampnr crank pulley
Stock gsr tranny
Act Clutch
Act Flywheel
Stock Axles
MSD 3 bar map sensor
Asking $65
Omni Power upper A arms
Custom Catch can with lines
Sold!!!!!!!!!!!
Sparco Seat (with your choice of civic or integra seat rail)
Asking $225
Mishimoto alum radiator with fan
Asking $200
Complete Fuel system
Aeromotive A1000 pump
Aeromotive regulator
Jegs 10gal fuel cell
Jegs inline fuel filter
10an feed and return line with fittings
Asking $600
Hondata s300 with p28 ecu
SOLD!!!!!!!!!!!!!!
Msd distributor cap with blaster ss coil
Asking $75
Rear disk conversion, has one new caliper and wheel bearing and arp ext. wheel studs. Also comes with steel braided lines for the rear and front.
Asking $300!!!! local pick up only
Tokico Illumina struts(installed but never used) with skunk2 coilovers.
SOLD!!!!!!!!!!!
Aem Wideband (new)
I will be adding More stuff as i take it off the car. I am also parting out the 92 hatch so let me know if you need parts.
Old Jan 24, 2010 | 12:33 AM
shepard4396's Avatar
Default Re: COMPLETE PART OUT
wow bump for some nice stuff
Old Jan 24, 2010 | 02:48 AM
b18integraboy's Avatar
bump. if you still have the radiator with fan in two weeks i will take it off your hands
Old Jan 24, 2010 | 07:41 AM
Thanks man!
Old Jan 24, 2010 | 07:52 AM
rich'shach's Avatar
i am interested in ur setup give me a call 717-777-1013 rich thanks
Old Jan 24, 2010 | 07:54 AM
civteck84's Avatar
bump for some deals. where does the catch can mount? -an size? and willing to part the dampner? pm me.
Old Jan 24, 2010 | 08:12 AM
JDM H2B EK's Avatar
you have a pm sir
Old Jan 24, 2010 | 08:36 AM
I hope this helps on the catch can mount location! In order to use it where i did you must move the battery. PM me back if you guys are still instrested in the catch can.
Old Jan 24, 2010 | 08:43 AM
JDM H2B EK's Avatar
you have a pm agian..
Old Jan 24, 2010 | 05:51 PM
javaa09's Avatar
pm sent
Old Jan 24, 2010 | 06:09 PM
javaa09's Avatar
lmk...i would like to get this set up if its legit
Old Jan 24, 2010 | 06:24 PM
Spoolin18's Avatar
Does the catch can have a drain-back to the block?
Old Jan 24, 2010 | 07:27 PM
ty521825's Avatar
nice parts. bump for u. if the catch can setup is kicking around in a few weeks i'll take it for sure.
Old Jan 24, 2010 | 07:42 PM
92bseries's Avatar
what kind of wiring issues r u having??
Old Jan 24, 2010 | 09:27 PM
Its got an an fitting at the bottom to either drain back into the block or just plug with an AN fitting.
Old Jan 24, 2010 | 09:33 PM
Well at first the the cabin and engie wire harness was kind of hacked up plus I did a wire tuck. I went to try to start the car and could not get the car to spark or the injectors to pulse. I swapped out the dizzy, ecu, just about everything i can think of before I swaped out the cabin and engine harness. After i put a new cabin and engine harness I had the same luck then the head lights quit working on the new harness. I just decided to part eveything and buy another car since I do need a good DD car.
Old Jan 24, 2010 | 09:34 PM
Thanks man!!!!
Old Jan 24, 2010 | 09:36 PM
Originally Posted by javaa09
pm sent
PM SENT!!!!
Old Jan 24, 2010 | 09:47 PM
JDMTOKER's Avatar
Is that $100 shipped for the catch can? If so let me know
Old Jan 24, 2010 | 09:52 PM
JDM_JNKY's Avatar
ill project
Old Jan 25, 2010 | 06:37 AM
CATCH CAN IS SOLD
Old Jan 25, 2010 | 06:50 AM
JDM H2B EK's Avatar
u sold it?
Old Jan 25, 2010 | 06:51 AM
javaa09's Avatar
dang it!!! I wanted that too!!!
Old Jan 25, 2010 | 07:43 AM
ryddlebox's Avatar
BUMP for nice prices and I really wish i could take that long block off your hands. GLWS
Old Jan 25, 2010 | 09:22 AM
92bseries's Avatar
damn sad 2 hear, i had problems similar to that couple years ago and had 2 sell the hatch, and i had 2 get another. jus got a job so hopin i can get some stuff off u shortly
