Car starts then dies right after
I've got a 94 accord and the thing will start up and then die right after. Also when I turn the key to the "on" position none of the indicator lights on the dash light up and all the windows and sunroof won't work either. I'm assuming all these symtoms are linked. Anyone have any ideas. Is it the main relay? Ignition switch?
Check if you have spark, compression, and fuel coming in.
Also, do you hear the fuel pump prime(make noise) after cranking the key to "ON" position?
Sin-D
Nov 14, 2007 05:31 PM
