02 Accord optimum camber for autoX
I'm running:
Eibach Sportline springs
Koni yellow shocks
20 mm rear sway bar
205/60-15 Yoko ES100 tires
The car is lowered 2 inches. I only ended up with -0.6 deg of camber up front, and -2 and -1.4 rear camber. The rear camber was uneven even before the drop, but I got that zero'd out with an Ingalls camber kit. As of now, the car handles much better than stock, but it still understeers. I'm aiming for a neutral handling and looking for some baseline camber angles to play around with. I'm also looking for suggestions on a front camber kit that will hold up to spirited driving and autoX.
Koni yellow shocks
20 mm rear sway bar
LX4CYL
19
Nov 1, 2004 11:53 AM
thehondabuddy
May 17, 2003 01:44 PM
hicamjunkie
11
Dec 31, 2002 07:13 AM
