Auto to 5speed swap ???
Okay so my 5speed 91 lx was t-boned this summer and I now hve found a nice shell (1990 lx) the shell is complete and good condition except for seized motor (dudes g/f ran it out of oil) only prob is it's a Automatic (not really a prob) What all do i need to swap over????? I know i need to swap ECU,cluster,But what else is different on the automatic models? do i need to swap intakes?? axels?? sencers???
Why would you need to do that. The wiring is under the carpet for the shifter, It's only a few wires to cut and solder, no need to swap an entire harness. Shift lockout and reverse lights.
okay,then the only ones i could find on the FAQ (that thing sucks btw) were for integras and eg's anyway i'm not using the backup lights anyway (gonna be using a 88-89 all red trunk panel,I just was wondering about the park lock out and the idiot clutch start switch
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/manual-pedal-cluster-auto-car-1220898/
http://www.gassavers.org/showthread.php?t=1033
Those were both in the 4th gen FAQ, I didn't even try google.
i recently did it on my hatch...its fairly easy...
if you say youre going to change your dash for now before you do it go to the junkyard and take out the whole pedal cluster from a 4th gen civic(sedan preferrably) if not hatch im pretty sure it wont matter the ones that change are wagovans so dont get a wagovan cluster
while your dash is out install the new pedal cluster with all 3 pedals and look for the precut hole on your firewall for the clutch cable...as far a throttle cable...they change depending on dpfi or mpfi....so i'd suggest getting them both just in case...
anything else let me know...
I'd love to mpfi but i'm a broke,the guy i'm buyin' the shell from said he'd take payments and i only got one more to pay,+ it's hard as hell to find mpfi parts in portland when i do find a setup they want 200$ bucks for it,guess i'm just cheep
well depends on your plans on the car...
if your planning to save up for a swap then dont mpfi your d15
but at some point youre going to have to deal with the MPFI wiring
93EJ2
Dec 15, 2007 02:17 AM
