FS: lots of parts in Lehigh Valley PA - b16 head, turbo built gsr bottom end,EF parts
call/text 6109058396
i have a b16 head that i just pulled of my motor to replace it with my built head. It just had valve adjustment and is really really really clean. It was reconditioned about a year and a half ago at my machine shop. new valve guides and seals with hardly any miles becuase it was in my weekend car. check out the pics...this is a jdm head stamped from 1988
comes with all internals, intake manifold, throttle body, valve cover, obd1 distributor, and rail. no injectors because i had rcs for my set up. i want $600
GSR bottom end Fully Built by whitehall machine shop. Block was taken apart, fully measured and inspected to spec. Crank was measure and micro polished and is in perfect spec. the block was fully cleaned and honed. it still has the assembly lube that he used to put it together.
Crower rods
stock b18c1 crank
Arias 9:1 pistons
tapped oil pan with -an fitting
brand new type r oil and water pump
brand new tensioner and timing belt
timing belt cover
looking to get $1500 for the bottom end alone
will give a little break if you want both the head and bottom end.
also have the turbo kit for this motor take it all and we can work out a deal
B series shift linkage for 88-91 civic - SOLD
YS1 trans cleaned polished no grinds - SOLD
ACT Extreme pressure plate with 6 puck sprung disc 100 miles - SOLD
CRX tail lights - black tint all 3 pieces- $60
Intercooler with piping for EF civic, upper pipe has blow off valve (name brand, forgot what brand) - $300
Skunk2 tuner 2 cams - $350 - SOLD
Stock GSR cams - $100
Drag log turbo manifold (t3/t4 external wastegate) $100
Drag 3" downpipe small dent on bottom (5 bolt turbo) - SOLD
3" exhaust bent for crx with a bullet muffler -$200
H22/H23 cast log turbo manifold for t3/t4 generic - $60
B16/B18c valve cover stripped to bare metal - $60
Precision Injectors 680cc - $250
B16 intake manifold/throttle body/fuel rail - $55
90-93 integra tail lights
Thermal Research EF exhaust - SOLD
apc short shifter in package - SOLD
B series rear t bracket for EF - $30
EG hatch rear spoiler off roof - stock - $20
EG energy suspension shifter bushings for d series - black - $15
EG half rad - like brand new - $40
slim fan - $30
DA rear seats - $20
Kicker Solobaric 12" sub in ported kicker box w/kicker grill and mtx 800rms watt amp - $375
GSR stock pistons and rods - good shape - $60
Crower rods
stock b18c1 crank
Arias 9:1 pistons
timing belt cover
slim fan - $30
DA rear seats - $20
bump, didnt know anyone posted so if your still interested in the bottom end let me know
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
call me.. im interested in the bottom end. 9737674812 i have a few questions.
depending if i can sell or use the parts id take trades...could use a big throttle body or a nice set of 15's or ef roll cage maybe some seats with ef hatch rails i dunno throw me some offers
negroeg6
Northern California (Sales)
24
May 18, 2011 03:49 PM
CRXherbie91
Aug 5, 2010 06:44 PM
WillieWillieFast
Nov 23, 2006 08:39 PM
iiilgsrlll
Jun 15, 2005 09:46 PM
