heater ??
Old Jan 22, 2010 | 08:12 PM
miguey310's Avatar
Default heater ??
well i bout a new civic but it doesn't have the ac set ,will the heater still work ?
if not wat do i need to make it work ?
Old Jan 22, 2010 | 08:26 PM
Creator's Avatar
Default Re: heater ??
AC set? Perhaps you mean the climate control in the dash?
Old Jan 22, 2010 | 08:32 PM
miguey310's Avatar
sorry i meant the whole ac unit
Old Jan 22, 2010 | 08:38 PM
teggi's Avatar
u need the box that goes under the dash for the heater to work...... oh and the blower too
Old Jan 22, 2010 | 08:39 PM
miguey310's Avatar
the box is near the glove department rite ? and where's the blower at ?
Old Jan 22, 2010 | 08:48 PM
teggi's Avatar
the box should be in between, dats the AC. the heater is right at the middle, and the blower is at the beggining of the passenger side (its white) you wont miss it
Old Jan 22, 2010 | 08:56 PM
miguey310's Avatar
jus took a pic
Old Jan 22, 2010 | 09:01 PM
teggi's Avatar
the one on the right is the blower, then AC, then heater.
you need the AC box just to have the heater.
gut out the AC box first...if u have one.
Old Jan 22, 2010 | 09:07 PM
miguey310's Avatar
which one is it ? http://www.hondamarketplace.com/show....#post39796374
after i get the box than what do i do ?
Old Jan 22, 2010 | 09:10 PM
teggi's Avatar
the AC box??? its the one in the middle....first make sure it is the same year as yor car other wise it wont work.......once you got the right AC box, open it, gute it out, put it back together, then put it in the car.
Old Jan 22, 2010 | 09:16 PM
miguey310's Avatar
so it's the white box rite ? and once i put the box back it will work ?
Old Jan 22, 2010 | 09:19 PM
teggi's Avatar
nope, the white one is the blower, the AC, is the one next to it
Old Jan 22, 2010 | 09:20 PM
teggi's Avatar
the small black box = AC
Old Jan 22, 2010 | 09:21 PM
miguey310's Avatar
so it's that one ok,so after i put the box wat the next step ?
Old Jan 22, 2010 | 09:25 PM
teggi's Avatar
make sure everything is connected and enjoy.
Old Jan 22, 2010 | 09:29 PM
miguey310's Avatar
great =D i might also get the ac too ,now wat would i have to do 2 make that work ?
Old Jan 22, 2010 | 09:33 PM
teggi's Avatar
if you wanna keep the AC, dont gut out the AC box. just keep everything in there and get anything that is missing from the AC, lines, condenser, etc, etc. and take it to a shop so they can charge it and check for leaks.
Old Jan 22, 2010 | 09:38 PM
miguey310's Avatar
oh ok well my car needs the lines and the condenser
where the line connect 2 ?
Old Jan 22, 2010 | 09:40 PM
teggi's Avatar
from the AC box to the condenser.......if you dont really know wat ur looking at or doing, just go to a shop with all the parts that you need, jst to be on the safe side.
Old Jan 22, 2010 | 09:42 PM
miguey310's Avatar
well ok thanks 4 the help bro
Old Jan 22, 2010 | 09:43 PM
teggi's Avatar
no prob
Old Jan 22, 2010 | 09:49 PM
miguey310's Avatar
no prob
good lookin out bro
pKjai
Aug 5, 2010 04:45 PM
slowhitEJ1
Welding / Fabrication
May 22, 2010 04:49 PM
daw1989
Sep 26, 2005 02:32 PM
HybridHatchC1
Apr 30, 2004 05:33 AM
2000_Civic_Si
15
Aug 22, 2002 08:28 AM
