hatch side moldings on a coupe? *pic*
Old Sep 4, 2002 | 10:03 PM
Draggin99Si's Avatar
Default hatch side moldings on a coupe? *pic*
Anyone know if civic hatch side moldings are the exact same size as the coupe? I have 1 final exterior mod left to do to my car, and that is to drop in the oem ctr flat side moldings. Is the total length the same? Should all the plugs in the back match up with my 99 coupe? Here's the ctr moldings:
Old Sep 6, 2002 | 06:59 PM
teg92's Avatar
Default Re: hatch side moldings on a coupe? *pic* (Draggin99Si)
legit question, bump for you.
Old Sep 6, 2002 | 07:02 PM
functionFiRst's Avatar
Default Re: hatch side moldings on a coupe? *pic* (teg92)
that's probably the last thing i would get on my car...those do look good though.
Old Sep 6, 2002 | 07:15 PM
l0p3z's Avatar
i tried to email jdmhondaparts, but the sales rep didn't know if it fit the coupes. however, i was told that the molding fit on the coupe, but i cannot verify that for sure. when you do find out, let us know.
Old Sep 6, 2002 | 07:32 PM
Civicboy's Avatar
Default Re: hatch side moldings on a coupe? *pic* (l0p3z)
go outside and measure the moldings on your coupe and I will mesure the moldings on my hatch and post them.
Old Sep 6, 2002 | 07:47 PM
MTK Kommander's Avatar
Default Re: hatch side moldings on a coupe? *pic* (MikeRotch)
yeah.. i can understand getting them because they're more flush, but if i heard someone say "im gonna get the EK9 moldings so i can achieve that JDM look" i would laugh..
Old Sep 6, 2002 | 09:12 PM
Default Re: hatch side moldings on a coupe? *pic* (chrisonepointsix)
I actually already told the body shop to shave my side moldings, but they said I will not be happy with the final results. They must not have enough experience shaving sides so then I heard that, it scared me since that is not something that is easily irresversible. That is the reason why I backed out. I have shaved everything on my car except side moldings when I recently got my car repainted a month ago.
Now since the side moldings weren't shaved, to get that "cleaner" look with what I'm left with now, something where I'm sure I will be the only one that will notice and no one else on the road, I want these ctr moldings. Trust me, I'm all about the clean look. There are things on my car that would be considered anti-JDM, but because they made the car "cleaner", I did it that way For instance, I passed up on a cf hood, but instead chose to shave my washer nozzles and repaint the oem hood, why because to me it looks cleaner. That is going against JDM. I love JDM, but I'm not bounded by it.
Civicboy, I will grab my tape measure and be back in a bit.
Old Sep 6, 2002 | 09:14 PM
CF hood doesnt have **** to do with JDM.. dont let this board fool you.. JDM isnt a style, and putting black rims and a black hood on your car doesnt make it JDM..
Old Sep 6, 2002 | 09:22 PM
iNteGraz92's Avatar
Default Re: hatch side moldings on a coupe? *pic* (MTK Kommander)
how about putting amber corners on ur car?
Old Sep 6, 2002 | 09:27 PM
Civicboy, I just got the measurements, here they are:
front fender: 5 and 2/16" (+/- 1/16")
door: 50 and 1/2" (+/- 1/16")
rear panel: 17 and 1/2" (+/- 1/16")
Do these match up to your hatch? Thanks man
Old Sep 6, 2002 | 09:30 PM
Are you in a bad mood or something? How about this.... "Japanese styling"
Old Sep 7, 2002 | 01:26 AM
SiB16AVTEC's Avatar
I've actually thought about doing that also to my coupe, so i measured it awhile ago with the 99-00 hatch i found on my block. The length at the points from the edge of the door to the rear wheel (the molding where the VTEC decal is located below it) is the same length as the hatch. The ones for the door and the wheel fenders should fit since they are essentially the same. But yeah, i hope that helps a little.
Old Sep 7, 2002 | 03:19 AM
well.. from 99% of the pictures ive seen.. most of the "japanese styled" cars all have kits and ****.. what most people here do, is try to make their car equal to the STOCK version of the japanese car.. so they order the parts that come stock over there, like clusters, sidemarkers, tail lights, etc.. basically all you have to do is bring over a japanese car and lower it on some slipstreams and its tight?
Old Sep 7, 2002 | 10:44 AM
Civicboy's Avatar
Looks like your good to go. the door and the fender should be the same and your measurement for the rear piece is the same
millertime191
Mid-Atlantic (Sales)
May 21, 2010 01:39 AM
ek9-08
Jun 26, 2009 11:50 AM
turbotime
Apr 18, 2005 08:39 AM
gribbs
Apr 12, 2003 10:40 PM
