how much can i get out of pump gas
Old Jan 22, 2010 | 11:29 AM
hondapimp125's Avatar
Default how much can i get out of pump gas
i'm currently starting to get closer to finishing my winter project and i was wondering approx how many pounds are pushable out of some 93oct pumpgas?
thanks ahead of time for any help
basics of my setup-
jg sleeved b20 84.5mm
9:1 cp pistons
eagle rods
b18b head-
p&p
crower springs, retainers, stage 2 boost cams
ferrera 1mm oversized intake/exhaust valves
t3/60-1
walbro 255hp
Old Jan 22, 2010 | 11:39 AM
boostedEF91's Avatar
Default Re: how much can i get out of pump gas
its not how much boost you run. every setup is different. . its how much hp pump gas can handle... 550 hp is usually the limit on pump tho. IMO. with the setup you have tho that turbo is going to max out before you reach the limit on pump gas.... But you'll be fine with your setup with making some good power.
Old Jan 22, 2010 | 11:40 AM
narfdanarf's Avatar
the general rule of thumb is 175wtq/liter
Old Jan 22, 2010 | 06:59 PM
first off, thanks for the help.
secondly,
i understand its all on the set-up but i mostly see people tuned at like 13-15lbs on pump gas for street an then like 22-26lbs on race fuel.
i'm hoping to run like 17-20lbs on pump gas for the street and was just wanting to make sure i wouldn't have any problems doing so
b20beast83
Feb 19, 2009 02:38 PM
garage16.ca
Jul 21, 2008 01:21 PM
LudeToAHatch
Dec 24, 2007 01:02 PM
a1320addict
Oct 15, 2005 12:46 AM
