ERL Superdeck1 K24a4 Block, Pistons, Rods - BRAND NEW
Old Jan 22, 2010 | 09:13 AM
PrecisionH23a's Avatar
Default ERL Superdeck1 K24a4 Block, Pistons, Rods - BRAND NEW
I originally purchased this set-up for our shop car but due to lack of time I no longer am going to need it. We were planning on using this for a 800whp turbo set-up which we wanted to compete in but I'll never have time to dedicate to this project unfortunately.
I am a distributor for ERL... Sean and I carefully planned this set-up so it could make the power that I was looking for. I assume you guys are familiar with ERL so I won't beat a dead horse.
-K24 SuperDeck1
-Align Hone
-Cylinder Hone/Finish Hone
-Crankshaft Polish
-Balance rotating assembly
-Clearance sheet (100% Blueprinted bottom end)
-ERL s2000 Oil Pump (modified for higher rpm)
-Calico Coated Bearings (Main/Rod)
-Thrust Bearings
-10mm sealing bolts and washers (for block)
-ERL Packaging
-Crower Billet Rods - Honda K24
-CP Honda K24 Hybrid 88.00mm - 9.0:1
-CP Piston Rings
-PRO PIN Upgrade - 866x2.250x200/22mm - CHAMFER
-K24a4 Crank (Polished - Not pictured - still in box)
Asking $4400 for EVERYTHING with the K24a4 block included in the price (no core needed). If you are interested in having this block assembled I can do so for additional. I've dealt with ERL and have been assembling their engines for over 4 years ranging from simple 250whp NA stuff to 800whp turbo set-ups. I'm sure Sean over at ERL will also vouch for this engine if needed.
Since this engine is completely balanced and blueprinted with all of the components listed I would prefer not to part this out. NO TRADES. PERIOD.
Old Jan 25, 2010 | 06:50 AM
Default Re: ERL Superdeck1 K24a4 Block, Pistons, Rods - BRAND NEW
bump
Old Feb 17, 2010 | 09:16 AM
still available
Old Feb 17, 2010 | 11:48 AM
kptrulee's Avatar
solid bottom end
Old Feb 27, 2010 | 01:01 PM
RSant's Avatar
Bump.. Nice setup wish i had the cash
Old May 4, 2010 | 12:02 PM
Still available!
Old May 10, 2010 | 07:17 AM
bump
TcUiRvBiOc
May 16, 2007 01:29 PM
salt
Mar 2, 2006 02:56 PM
B18C1CYA
May 22, 2005 09:05 AM
