BUILDING B17 MOTOR
I HAVE A 92 INTEGRA GSR WITH ORINGINAL MOTOR IN IT. IT SMOKES AND BURNS OIL. SO I WAS THINKING OF REBUILDING MY MOTOR. THE ONLY PROBLEM IS THAT THIS IS MY DAILY DRIVER. SHOULD I DO THE BLOCK OR HEAD FIRST. DONT HAVE THE MONEY TO DO BOTH AT THE SAME TIME. ANY HELP
you may be better off swapping something else in there temporarily until you have the scratch to rebuild it.. if it smokes and burns oil, you probably have bad valve seals or burned/broken piston rings...
500 bucks on craigslist could probably get you a b16 to bolt in, then just drive that while rebuilding your engine? idunno.. rebuilding engines is costly, and i doubt you will find a replacement b17
smokinloc
Jun 25, 2010 08:03 AM
