Blox stage 1 cams ??? Work with JRSC???
If you don't know alot about cas then I wouldnt other to buy one. You'll most likly need springs, retainers, and valves if you want to have your Teg Reliable. Research and see if thats cam is good for SC set-ups. Because it might just make you end up losing HP.
Jared
Jared
forget about that! you want the best known combo which is itr ex cam and gsr intake cam, second best ctr ex cam gsr intake cam third choice gsr cams, or b16 cams, or gsr intake b16 ex cam, iv used sk2 pro 1 cams they made ok power and kept dynamic compression down but i could of still made more with any of those other combos, im curently using the most aggressive oem cam, the ex. cam from the 01'' spec itr and 01'' spec gsr intake cam.
