89 EF hatch NO start D16Z6 sWAP ....IDEAS???
Old Jan 22, 2010 | 07:07 AM
FSS13foxtrot's Avatar
Default 89 EF hatch NO start D16Z6 sWAP ....IDEAS???
1989 Civic SI hatch
d16z6 swap
Obd1 dizzy/ ecu / injector plugs/ distributor plugs
Rywire OBD0 to OBD1 MPFI jumper harness
-Firing order correct
-grounds all there
-fuses are all good
-Main relay?
-i have not had time to check for codes since i got work right now.....will do when i get back
All wiring is correct on the distributor plugs, i have verified this over and over.... fuses look good, grounds are all connected. battery has juice, and i attempted to jump start to make sure this was not an issue at all. any ideas would help......please dont ask me ?'s unless you plan to reply to my answers.... a million honda brains is better than one for ideas......lets see what we come up with.....
Old Jan 22, 2010 | 07:11 AM
91' LS-VTEC's Avatar
Default Re: 89 EF hatch NO start D16Z6 sWAP ....IDEAS???
so it cranks, just wont kick over?
Old Jan 22, 2010 | 07:27 AM
lunalink's Avatar
Old Jan 22, 2010 | 07:51 AM
crx_si-r's Avatar
first things first. you said you checked the wires on the distributor. there are 2 wires a white and cream colored wire on the distributor and engine harness. did those get swapped around? when i did my first obd1 conversion i had the same problem, swapped the wires and it started right up. try that. if you still have the same problem try another ecu, your current ecu might be bad.
Old Jan 22, 2010 | 06:05 PM
i will look at these tonight, posts tomorrow evening after work.....good thinking, i looked at the dizzy wires over before, i will check again. and yes that is correct it will crank just not turn
Old Jan 22, 2010 | 07:42 PM
do you hear the fuelpump prime, when you turn the key?
Old Jan 24, 2010 | 12:10 PM
i do not hear the fuel pump, but i do hear the relay click, ill try swapping out the relay/ hitting the tank with a rubber mallet to test the pump.
messy.
Feb 12, 2018 12:44 PM
efhonda_21740
13
Jul 15, 2011 10:48 AM
clubef9
Apr 16, 2007 03:22 PM
iNetForce
Jul 12, 2004 12:26 PM
KOOL-AID
Oct 21, 2003 01:17 PM
