alarm+trunk
Old Jan 21, 2010 | 12:05 PM
oh_dam's Avatar
Default alarm+trunk
hey guys, i recently installed a autopage alarm myself and everything is working except that i can't figure out how would i wire the alarm to the trunk any type of info would help
Old Jan 21, 2010 | 01:41 PM
w211 ryda's Avatar
Default Re: alarm+trunk
1994-01 Acura Integra
WIRE COLOR LOCATION
12 VOLT CONSTANT FAR LEFT OPTION OUTPUT ON FUSE BLOCK
STARTER BLACK/WHITE MAIN RELAY
IGNITION BLACK/YELLOW UNDER DASH FUSE BOX
PARKING LIGHTS (+) RED/BLACK REAR QUARTER HARNESS
TRUNK TRIGGER (-) GREEN REAR QUARTER HARNESS
DOOR TRIGGER (-) LIGHT GREEN/RED DRIVER'S RUNNING BOARD
FUEL PUMP (+) YELLOW/GREEN (THIN) DRIVER'S RUNNING BOARD
POWER LOCK (-) BLACK/WHITE DRIVER'S KICK
POWER UNLOCK (-) BLACK/RED DRIVER'S KICK
Old Jan 23, 2010 | 12:40 AM
sik96teg's Avatar
above is correct u can find the wire right at the trunk lock itself. if your referring to setting up the alarm to open the trunk you can get a trunk popper off of ebay for about 25 bucks. pretty easy to install
Old Jan 23, 2010 | 01:12 AM
DCRB's Avatar
just throwing it out there, be sure to always use a diode on the accessory trigger wire. (the wire you use to detect the hood or trunk being opened). that way the trunk light doesn't come on when the hood is popped, and other things don't get screwy.
Old Jan 23, 2010 | 01:48 PM
sik96teg's Avatar
that shouldnt matter. the alarm should have its own wire for the hood. ive never used a diode n any of my hondas but ive only used compustar and viper alarms.
Old May 7, 2010 | 06:08 AM
vsm_dc4's Avatar
so if i were to install the trunk trigger on my alarm to my trunk, i would need to go out and buy a trunk popper just so it would work.?
Old May 7, 2010 | 10:03 AM
RICKSAUTOMOTIVE's Avatar
yes. the trunk popper in there now is cable actuated. you need an electric one for the alarm to electrically signal the trunk to open. IMO if your alarm has a sensitivity setting you shouldnt need a popper to scare off anyone opening the trunk. only if you wanna look cool walking to your car and popping the trunk with you alarm. hardly anyone would notice though IMO.
Old May 7, 2010 | 07:19 PM
sik96teg's Avatar
it does come in handy especially when i go grocery shopping u can disarm and pop the trunk before getting to the car. its usefullness is no different than having keyless entry. who is going to setup an alarm and not wire up keyless entry. it just makes life easier.
Old May 7, 2010 | 11:40 PM
oh_dam's Avatar
my integra didnt came with cable trunk release, its the automatic lever one, but for some reason the lever dont have no power to it, but the actuator does cause i can hear it lock and unlock when i arm and disarm the car
Old May 8, 2010 | 09:00 AM
i assume you have checked the wiring in the leaver then? or maybe the lever pushes a switch and the switch is bad?
BrotherAli
Audio / Security / Video
17
Oct 19, 2012 11:56 AM
Benard
Oct 16, 2008 08:52 PM
JLEK
May 22, 2007 09:04 AM
InTeGrA B18b1
Dec 30, 2003 03:36 PM
yoshi234
Feb 12, 2003 08:29 AM
