should i get skunk2 or ferrea valves
Old Sep 4, 2002 | 08:38 PM
Black DC2's Avatar
Default should i get skunk2 or ferrea valves
i think i bent some valves in my 98 gs-r so should i get ferrea or skunk2 i heard
that you need to get the whole valve train if i get the ferrea valves i just want the standard valve or should i just get the skunk 2 valves
please help
Old Sep 4, 2002 | 10:59 PM
MikeSarr_GSR's Avatar
Default Re: should i get skunk2 or ferrea valves (mighty goku)
no dude, dont waste your time with stainless steel valves. they will flatten your valve seats eventually and cause more damage than they are worth. not for use in a daily driver. Get the ITR intake valves, get em cut and be done with valves. The actual seating surface is so small, with the SS valves, they make em even smaller... over time the flame travels up the seat and cuts components like a welding torch... actual power gained from valves... well if they
are flat you may see +.5 cr and a few extra whp, but is it really worth it? How the valves move in relation to the combustion in the cylinder is the way to make power, even there are limits to cam timing and cam choices for the street.
[Modified by MikeSarr_GSR, 8:01 AM 9/5/2002]
junkyard racer
Sep 7, 2008 04:41 PM
dand39
Feb 16, 2005 11:47 PM
BigPlansNoMoney
Nov 2, 2004 06:45 PM
