Transmission & Drivetrain Gearboxes, Differentials, Clutches
Where do you put the transmission fluid?
Old Jan 20, 2010 | 12:22 PM
DrewBrews's Avatar
Default Where do you put the transmission fluid?
i am planing to flush out and add new transmission fluid but first WHERE THE HELL IS IT?!?!
Old Jan 20, 2010 | 04:58 PM
Honda Bull's Avatar
Default Re: Where do you put the transmission fluid?
Well...for us to answer that very thoroughly, you first have to tell us the engine you have in the vehicle, so we can instruct you on where it is.
Old Jan 20, 2010 | 06:00 PM
Maluko's Avatar
it goes inside the tranny guey. no mames.
Old Jan 20, 2010 | 07:03 PM
DrewBrews's Avatar
its a gsr engine.
Old Jan 21, 2010 | 07:56 PM
Honda Bull's Avatar
In the space between the battery and the throttle body, look down at the axle going into the transmission. Behind the axle hub, there will be a 17mm bolt which is the FILL plug. Below that is a 3/8" ratchet bolt that is the DRAIN plug.
niceprelude
10
Feb 8, 2009 04:20 PM
vmp2002
Jul 3, 2007 05:25 PM
UrbanEh
Jun 21, 2007 02:08 PM
copmagnet
Oct 19, 2004 05:54 PM
ludeR917
Nov 16, 2003 12:09 PM
