has any body tryed this swap?
Old Jan 19, 2010 | 05:49 PM
lude72's Avatar
Default has any body tryed this swap?
b18 block,b20 crank and rods, b16 pistons and vtec head. does any think it will work? if so will it make more torque then an lsvtec swap? just an idea
Old Jan 19, 2010 | 07:03 PM
LowBudgetBEe's Avatar
Default Re: has any body tryed this swap?
dont know why im answering but this is bascially an ls/vtec w/b16 pistons. its been done a million times. b20 and b18 have same crank unless ur talking about the b20a from prelude
Old Jan 20, 2010 | 05:28 AM
lude72's Avatar
i wasn't sure about the b20 stroke thanks for the info . will the b20a5 (prelude) crank fit in a b18/20 block?
Old Jan 20, 2010 | 01:56 PM
ryddlebox's Avatar
yep done it, have tuner ready BEFORE running it though we did one just to see how it would run. it was ok, untuned but ended by melting the side off 2 pistons. and ruined the block. under 500 miles
Old Jan 21, 2010 | 03:17 AM
lude72's Avatar
did you ever tune it ? how did it run lots of torque and rpm ?did you used a prelude b20a5 crank and rods , b18 block , b16 piston ,and vtec head?
Honda_Fanatic
Dec 14, 2007 10:47 AM
bluesihatch
10
Mar 19, 2007 07:51 AM
bmilescrx
Apr 21, 2004 01:43 PM
theSQad
Jan 20, 2004 07:20 PM
