Cig. Lighter Wiring
Old Jan 19, 2010 | 02:34 PM
Dunc's Avatar
BCICAN
Default Cig. Lighter Wiring
Does anyone know how to easily change around the cigarette lighter outlet wiring to have a constant/direct connection to the battery?
I have a solar battery charger that I want to connect via the cig. lighter outlet. When the car is off there is no electrical connection through the cig. outlet (checked with a multimeter). Thanks.
Old Jan 19, 2010 | 03:00 PM
TunerN00b's Avatar
Default Re: Cig. Lighter Wiring
Look at the fuse box under the dash.
There should be connections available for an "always on" line to tap into.
The wires from the back of the cig lighter itself should also be there, tied into the fuse panel, in case you'd rather re-wire that instead of running new wires.
Old Jan 20, 2010 | 04:59 AM
Dunc's Avatar
BCICAN
Yeah I'd much rather just put move the current wires around at the fuse panel rather than running all new wires. Thanks for the input.
siblues
Audio / Security / Video
Apr 14, 2011 05:09 PM
RPM_69
10
Jun 9, 2010 05:28 AM
acurahb
Sep 30, 2007 12:03 AM
pearlws
Honda S2000
Feb 19, 2004 04:46 PM
Jinxed
Dec 11, 2003 10:33 AM
