What color wire should I look for to wire something to 'ignition'?
Old Sep 4, 2002 | 06:52 PM
Jonathan_ED3's Avatar
Default What color wire should I look for to wire something to 'ignition'?
Got a wiring problem that's running my battery down when it sits for a few days..
I want to run it to 'ignition on'....what color combo wire should I be looking for and where's a good place under the dash to do it at? TIA!!
Old Sep 4, 2002 | 06:57 PM
Default Re: What color wire should I look for to wire something to 'ignition'? (hot_EG)
ttt...i need to do this ASAP guys
Old Sep 4, 2002 | 07:18 PM
kwhitelaw's Avatar
Thick guage wire at the ignition harness, black with a yellow stripe.
Old Sep 5, 2002 | 05:37 AM
keithv's Avatar
Default Re: What color wire should I look for to wire something to 'ignition'? (kwhitelaw)
you could plug into one of the empty slots in your fuse box.
Old Sep 5, 2002 | 06:19 AM
audioroach's Avatar
Default Re: What color wire should I look for to wire something to 'ignition'? (breaka_1_9)
Ditto........in your fuse panel there resides a row of male ports...one of them will provide ignition...not to mention battery...lights etc.
Old Sep 5, 2002 | 10:12 AM
ScottEK's Avatar
Default Re: What color wire should I look for to wire something to 'ignition'? (audioroach)
I'm sure these guys are right but if you can't figure it out you can just go off of your radio fuse. I used to wire my radar detectors to that fuse because it shuts off with the car. Just strip the wire and stick it in with one of the posts, I wouldn't suggest doing it on large draw items without upgrading the fuse, plus it's just a very ghetto way of doing it.
kinick313
Audio / Security / Video
May 26, 2007 11:52 AM
staticrex
Dec 8, 2004 11:46 AM
SIMATIC
Jul 30, 2003 01:19 PM
