Honda S2000 Honda S2000
Oil light after spinning out...?
Old Jan 18, 2010 | 07:48 PM
enzozenuni's Avatar
Default Oil light after spinning out...?
Okay so here is the story i was taking a bend and i gave it some gas to whip the tail a little and it started to slide it was going very good as i was maintaining the drift i gave it to much gas by accident and it ended up spinning out and it did a 180 and the passenger side tire hit a small ascending curb basically its a curb shaped like this / a little lower its not a bad one my front right tire hit and as the car hit it, it slid a little more and then at that same moment the check oil light came out. and the rpms went very low so i turned the car off tried to turn it on again and it wouldn't turn it kept trying to turn on but it wouldn't so i let it sit for a 30 seconds and it turned back on again.. the oil light came back on and then turned off and the rpms settled and went back to idle at 1k and everything worked fine no oil light nothing. Everything went back to normal..
What do you guys think could of happened?
Old Jan 18, 2010 | 08:13 PM
enzozenuni's Avatar
Default Re: Oil light after spinning out...?
anyone?...
Old Jan 18, 2010 | 08:15 PM
mrharmonic's Avatar
**** dude i have no clue lol bump
Old Jan 18, 2010 | 08:19 PM
enzozenuni's Avatar
lol me neither i had the most clueless and just s**t my pants face ever when it happened lol
Old Jan 18, 2010 | 08:23 PM
enzozenuni's Avatar
also i did change the oil about 2 weeks ago and i put 5.9 quarts thats what the guy at autozone said when he looked it up... maybe to much oil? as it hit the curve it got over filled with oil?
Old Jan 19, 2010 | 01:09 AM
Ben850's Avatar
well, what does your dipstick say?
Old Jan 19, 2010 | 05:24 AM
JDMF22B's Avatar
In city drifting ftl.
But to answer your question it's much like if you take a long turn hard in your car, and your gas meter looks like you used a gallon of gas but it settles back down after a couple of minutes. Your oil level probably just read high thus the light. Guarantee you're fine.
Old Jan 19, 2010 | 05:45 AM
enzozenuni's Avatar
thats what i was thinking. do you guys think those aftermarket oil pans like the spoon ones resolve these problems?
Old Jan 19, 2010 | 06:07 AM
JDMF22B's Avatar
If it's this incident your concerned about, why not just a little less oil in it? and/or chill on the drifting ;P
Old Jan 19, 2010 | 06:12 AM
c-rex23's Avatar
i use 5 quarts of oil the books does says a lil more but 5 is fine
Old Jan 19, 2010 | 07:42 AM
SirStig's Avatar
ya 5.9 seems like a lot to me. I use 5 and have no issue. G-force can do a number on your fluids in the car.
Old Jan 19, 2010 | 08:05 AM
enzozenuni's Avatar
yeah 5.9 does seem a lot for me too. I guess I'll pour some out.
Old Jan 19, 2010 | 07:59 PM
Targa250R's Avatar
be professional
cool story bro
Old Jan 19, 2010 | 08:01 PM
green-'s Avatar
areyou talkin g-force street performance? yeah dawg those products will boost your car to levels unforeseen
Old Jan 19, 2010 | 09:29 PM
SirStig's Avatar
no just plain old g's that can move the fluids in your car if you sliding around too much
Old Jan 19, 2010 | 10:05 PM
enzozenuni's Avatar
Well it was the hit of the curb that caused all that i guess from the hit it was kind of a shock for the car.
Old Jan 20, 2010 | 04:16 AM
Techno Tonis's Avatar
Okay so here is the story (MASSIVE WALL OF TEXT WITH NUMEROUS SYNTAX AND GENERAL GRAMMAR ERRORS)
You bought a car that you don't know how to drive.
Old Jan 20, 2010 | 05:30 AM
90Rexx's Avatar
lol!!
maybe the g forces slid all the oil away from the oil pickup so there was a small period of time where the oil pump didnt pickup any pressure.
Old Jan 20, 2010 | 06:25 AM
White Smoke's Avatar
i my honda
Global Mod
Your burning or leaking oil, you have not checked it since your change, you were low on oil and did a hard turn which ended up starving you oil pickup.
You should have never tried to start it back up before checking/adding oil. You should have known this... There is a chance you scored your bearings.
End Thread
Old Jan 20, 2010 | 11:28 AM
enzozenuni's Avatar
very funny...
Also the car is not burning any oil. It doesn't smoke at all.
Old Jan 20, 2010 | 11:29 AM
enzozenuni's Avatar
as for the grammar. Its a forum not a english class. FYI I speak 3 languages. English is not my main.
Old Jan 20, 2010 | 12:00 PM
BondoBuilder's Avatar
Yes the baffling in the Spoon oil pan will help eliminate oil starvation (lack of oil lubricating engine components due to G force caused by gravity and pull during hard turns), however it is not required if you only occasionally street drift
BTW F20's and f22's only need 5 to 5.1 qts oil. Too much oil will not effectively lubricate the engine; it will have a similar effect to too little oil.
Old Jan 25, 2010 | 07:42 AM
i my honda
Global Mod
very funny...
All S2000's burn some oil, especially synthetic and super especially Mobile 1! Have you actually checked the oil since this happened, you may be surprised...
Old Jan 25, 2010 | 07:50 AM
JDMF22B's Avatar
A majority of honda's "sportier" cars (i.e. prelude), are notorious for burning more oil then normal. I'm sure he's fine, although checking oil should be a regular thing anyway.
Also, question: Can't excessive oil cause some issues down the road, like when you add more gasoline than you should?
Old Jan 25, 2010 | 09:07 AM
Well on that note,
You're driving on public highway, not a racetrack.
And you drive a Honda, not a Porsche.
You don't have a fancy dry sump system that babies your bad driving habits.
Try to keep that in mind next time you wanna go out for a joyride, Tokyo Drifter. Don't know what state you reside in, but most cops only speak English in the good ol' U.S.
I suggest if you are going to out of your way to grab their attention, you better get a better grasp of the language they speak.
very funny...
Oh, the car is burning oil...just not enough for you to notice.
