High Idle HELP ME
Old Jan 18, 2010 | 02:09 PM
KiTTeN.MiTTeNs.'s Avatar
Default High Idle HHHHHEEEEEELLLLPPPPPPP
A little background on the car.
91 LS B18b1 bottom end with a1 head.
guy i got it from had one cam off time by one tooth.
fixed that. timed it at 800 RPM. (cant get it to go lower)
now... when the car is cold RPMs go to about 2 grand. as the car warms, the idle goes down.
when its warm, it sits at about 1200, mind you i have the idle screw all the way in.
also when i lift on the gas pedal, the idle goes down (is that normal?).
no vaccuum leaks, or air leaks of any kind.
anyone have any suggestions or past experiences?
please only post helpful information.
cheers, -mark.
Old Jan 18, 2010 | 02:22 PM
Default Re: High Idle...
bump
Old Jan 18, 2010 | 02:28 PM
mouab18c1's Avatar
Default Re: High Idle HELP ME
did you time your ignition timing with a timing gun?
Old Jan 18, 2010 | 02:29 PM
shiftmx179's Avatar
What rpm does the car idle at when it's warm at operating temperature?
Old Jan 18, 2010 | 02:32 PM
yes.
Old Jan 18, 2010 | 02:33 PM
1200, but its wierd, sometimes its around 800, but most of the time 1200
Old Jan 18, 2010 | 02:36 PM
you think it might be my IACV?
this is my first honda.
i had a rotary before this so bare with me
Old Jan 18, 2010 | 02:46 PM
bump
Old Jan 18, 2010 | 02:59 PM
bump
Old Jan 21, 2010 | 03:17 PM
UPDATE
ok, throttle cable adjustment was the warm temp idle problem.
i now want to get rid of the high cold start idle.
when i start the car, it goes to 2 grand and gradually decrease as the water temp goes up.
sometimes in the middle of warming up, the idle searches from 1200 to 1500.
also, whe i push in the clutch and let off the gas while driving the rpms go up 200rpms for a split second, then goes down to idle.
any suggestions?
Old Jan 21, 2010 | 03:27 PM
bump
Old Jan 21, 2010 | 03:32 PM
bump
Old Jan 21, 2010 | 03:41 PM
BUMP
Old Jan 21, 2010 | 04:19 PM
BUMP
Old Jan 21, 2010 | 04:24 PM
**** THIS
Old Jan 21, 2010 | 05:59 PM
cleaned my thermowax or whatever the hell you call it on a honda.
fixed my problem.
thanks for all the help.
cheers.
FloridaCivic
18
Feb 24, 2007 12:23 PM
ex94vtec
14
May 6, 2006 02:07 AM
jokr78
Dec 15, 2004 01:47 PM
goltz81
Dec 11, 2004 05:25 PM
vti-R
Jun 21, 2002 08:01 PM
