Results from switching Tranny Fluid
Well after my swap I decided I would go on some suggestions and try running Mobil One Synthetic 10w30 in my tranny. After about a night of hard driving, my previously smooth shifting tranny began to get a grind between 2nd and 3rd. My first thoughts- typical Honda tranny, bad synchro. Well I figured I'd give the Honda MTF a try to see if that helped at all before I evaluated my options for the tranny.....
I changed it out today and the results were pretty good. Previously any shift over 6k in 2nd would lead to a 3rd gear grind, that is no longer (at least most the time).
My first shift at 8k was clean w/ out a grind
The following shifts were pretty good too ( there still feels like a slight grind occasionally). I wouldn't doubt that I have a worn synchro, but the fluid change helped, and overall- even at low RPM the tranny shifts a little smoother in each gear. Damn synthetics
Just figured I'd share for those who care-
Brent
Brent
the tracy dealer in town recommends a 30w oil..DO NOT USE A SYN...syn. oil is too slippery for ur synchro s to grab...slippery is good for motors but not good for tranny s..so say s my honda dealer
if your honda dealer is recommenidng putting motor oil in your tranny, you should switch dealers NOW
Honda MTF is the only way to fly
Damn synthetics
Brent
Brent
I know Honda MTF is good, but Mobil-1 seems fine for GOOD transmissions, but seems to run into these problems like you describe in WORN transmissions.
Is there any long term testing out there by anybody else who uses synthetics in their trannies?
Shawn
[Modified by shawnhayes, 3:01 AM 9/5/2002]
I definitely agree- now especially. If you hunt around on this site you'll find people who use it with no complaints, thought I'd give it a try since I had about 3 quarts left over.
I definitely agree that Honda MTF is the way to go.
[Modified by ill phil, 3:03 AM 9/5/2002]
I definitely agree that Honda MTF is the way to go.[Modified by ill phil, 3:03 AM 9/5/2002]
Shawn- I believe you were in one of the threads I saw that recommended the mobil 1. I agree on the point of it being a worn tranny. I wouldn't doubt that my synchro's are still worn. They just seem to catch a little better now with the Honda MTF. From now on I agree with most that Honda MTF is the way to go, but dont get me wrong there are those who use synthetic and are happy
[Modified by ill phil, 3:04 AM 9/5/2002]
As for worn trannies, one could presume that Mobil-1 would prevent the synchros from "meshing" to begin their job properly. Honda MTF is probably formulated to let them "clash" with a little less drama.
But, I have this bet too. Even with a worn tranny, and some grinding of the synchros, I'll bet the tranny will last longer with my cocktail of higher weight Mobil-1 than Honda MTF. The problem is, though, with MTF, they'll probably last 250,000 miles, and with Mobil-1 I'd guess 300,000 miles, but I don't know anybody whose driven one that far. (yet).
Anyone, anyone?
Shawn
One other solution I've had friends use successfully is Redline tranny fluid. Havent used it personally, but they all commented on the nice feel and smoothness when they switched to it. Probably going to flush mine and fill it with Redline sometime soon.
i use neo mtf, work very well in my tranny. i downshift to 1st gear w/o grinding every lap at the 2nd hairpin in street of willow.
After the first post this evening I drove the car around all night and to our local Wed. night "meet". I do still think that the tranny is shifting a little smoother in low RPM and normal driving. Sadly I've realized that the synchro is definitely worn
The shift to 3rd is a lot easier than before as it catches sooner with less of a grind but the grind is still there- that sucks. I'm still happy with switching the fluid though, I really do think it feels better. I can definitely feel a difference in that shift from 2nd to 3rd.
Shawn, Yeah you are right on the fact that there really isn't any proven lifetime of trannies with either type of fluid.
Overall,
The shift to 3rd is a lot easier than before as it catches sooner with less of a grind but the grind is still there- that sucks. I'm still happy with switching the fluid though, I really do think it feels better. I can definitely feel a difference in that shift from 2nd to 3rd.Shawn, Yeah you are right on the fact that there really isn't any proven lifetime of trannies with either type of fluid.
Overall,
23
Oct 3, 2004 03:32 PM
SimbaDogg
Feb 22, 2004 10:11 AM
RagingAngel
Nov 8, 2002 07:13 PM
Dont think the 1 bottle I have is enough.
