best way to fix this chipping paint?(pics)
Old Jan 18, 2010 | 12:31 AM
skunk2FTMFW's Avatar
Default best way to fix this chipping paint?(pics)
what would be the best way to fix this?(without a complete respray of the bumper)
its a single stage sherwin williams paint that was painted in october..
help, ples..
Old Jan 18, 2010 | 05:08 AM
Hawkze_2.3's Avatar
Default Re: best way to fix this chipping paint?(pics)
You can sand down that area, feather out the sanding until the paint stops chipping, and then just spray that area and blend it in with the rest of the bumper.
Old Jan 18, 2010 | 05:31 AM
HighRevn's Avatar
Looks like whoever sprayed it didnt prep the area correctly. Chances are it will most likely do that on the rest of the bumper. But you can try out what Hawke said and see if that works
Old Jan 18, 2010 | 05:48 AM
IMPATIENT's Avatar
have fun blending single stage paint. not a highly reccomended thing to do if your not an experienced painter, if you dont know how to use blender correctly youll ruin it easily and that being said, that is a large area to use blender.Again not a highly recommended thing. Melting should ideally only be done on small areas. Blending finishes is only a temporary solution anyhow, itll eventually die back an your blend spot will show back up in less than a years time. your best bet is to sand all that crap off and respray the bumper. Someones lack of prep work is the reason for that stuff chipping off like that in the first place, sand it down and do it properly. Being as your asking how to fix that, I would bet to say your not even certain what blending finishes(not color)even is so dont do it man. Just sand it down, and respray it and make sure its prepped up well and youll be alot happier than trying to put a band aid on that bumper.
Old Jan 18, 2010 | 04:13 PM
thanks guys... nah it wasnt the painters fault. i backed into my sisters car. lol. thanks for the advice though. i just dont wanna pay $170 to get the bumper resprayed. what kind of paint should spray over and try to fix it with?.
Old Jan 18, 2010 | 04:45 PM
precisionsc54's Avatar
I knew by looking at it that it wasnt a prep or adhesion issue but had been hit. Just feather it out and reshoot the whole bumper or you will have problems
Old Feb 18, 2010 | 10:34 PM
mrharmonic's Avatar
bump
Old Feb 18, 2010 | 10:43 PM
gorillafart's Avatar
i'd probably scream at it and hope it fixes itself.
Old Feb 21, 2010 | 07:07 PM
Ziprock's Avatar
^ easiest solution
Old Feb 21, 2010 | 07:11 PM
tc1155's Avatar
New User
paint the whole bumper, it will end up being less of a headach. SW you car get from napa
IROCKCIVICS
Paint and Body
Mar 29, 2008 05:51 PM
m1ndless
Oct 5, 2006 04:12 PM
variablevalve
Nov 17, 2005 02:27 AM
Zuerst
Jun 25, 2003 03:27 PM
cd5_2NR
May 8, 2003 11:35 PM
