koni adjustables
i just had my stock struts upgrade d with koni cartridges..on the top is the adjustment rotor..the white, round adjusting tool has 8 knotch s...i want to know what the percentage of stock each knotch represents
there are no clicks..they adjust at the top and come with a round ****..i wish it was as easy as the advirtisement say..right now they re set at 3rd knotch till i find out where it should be
You can adjust them to full stiff by turning them counterclockwise until the adjuster simply stops.
I've seen numerous places that recommend that you back off 1/4 turn so you don't jam the adjuster.
Try full stiff and work your way 1 "click" u til you get the desired ride I guess.
I love my Konis
I love my Konis
ive tried it at half and its still way too stiff..i know the AGX s in the rear are about 15% stiffer than stock..a perfect match with the eibach pros..but i cant get the match for the front..so im now looking for % numbers on the fronts..with all the recommendations coming from everyone about the koni s ..i would have thought someone would know
I love my Konis
I love my Konis
travis
Aug 19, 2002 01:36 PM
