H23 intake manifold on f22a which thermostat housing
Old Jan 17, 2010 | 12:39 PM
ashb82's Avatar
Default H23 intake manifold on f22a which thermostat housing
I have a f22a sohc i am putting a h23 intake manifold on. which thermostat housing and metal pipe that comes from the water pump do i use.
Old Jan 17, 2010 | 03:00 PM
hondamark35's Avatar
Default Re: H23 intake manifold on f22a which thermostat housing
the original F22 housing and pipe should work. i don't think there is any notable difference between the two.
Old Jan 17, 2010 | 03:06 PM
ashb82's Avatar
I dont have the original stuff i was building the engine i had a head and block. So should i buy a h23 or f22a parts
Old Jan 18, 2010 | 03:08 AM
i'd probably go with the F22 just to avoid any unforseen trouble with the metal pipe (match the housing to the block). but if you found a better deal on the h23...
bigsnorlax
Jun 2, 2009 12:09 PM
hb_guy
Sep 8, 2006 08:18 AM
crazygangsta301
Jan 23, 2006 05:33 PM
