H23 intake manifold on f22a which thermostat housing
I have a f22a sohc i am putting a h23 intake manifold on. which thermostat housing and metal pipe that comes from the water pump do i use.
Re: H23 intake manifold on f22a which thermostat housing
the original F22 housing and pipe should work. i don't think there is any notable difference between the two.
I dont have the original stuff i was building the engine i had a head and block. So should i buy a h23 or f22a parts
i'd probably go with the F22 just to avoid any unforseen trouble with the metal pipe (match the housing to the block). but if you found a better deal on the h23...
